Go to Post GP is a much longer-term investment, yet offers surprisingly high returns. Just like 401(k) plans, the important thing is to keep making contributions even when it seems there's no reward for it. - ayeckley [more]
Unread 02-02-2008, 12:33
mjgard's Avatar
mjgard mjgard is offline
Michael
AKA: Michael Gard
FRC #2844 (Stampede Robotics)
mjgard will become famous soon enough
festo solanoid
when we charge our system the festo solanoids are leaking air and our system cant fully charge to activate. We cant find a specific leak. Any ideas???
Unread 03-02-2008, 03:37
itsme itsme is offline
FRC #2217 (FOMH)
itsme is an unknown quantity at this point
Re: festo solanoid
Did you wrap with teflon all the pneumatics connections?
We first didn't, and we had lots of air leaks, now after wraping with teflon there are minimal air leaks (nothing's ideal).
2007 Israel Regional GM/Technion Rookie Allstars
Participated in 2007 Atlanta World Championships (Newton Division)
Unread 03-02-2008, 09:28
Re: festo solanoid
Try blocking the exhaust port with a finger or loopback until your pneumatics system gains > 30psi.
The Festo pilot valve may be starting in a halfway or neutral state left over from the factory. The pilot valve requires a minimum of 30psi to shift properly and should normally be left in the home position where it automatically returns when powered down.
Unread 03-02-2008, 10:26
nickcvet89 nickcvet89 is offline
FRC #1228 (RoboTribe)
nickcvet89 will become famous soon enough
Send a message via AIM to nickcvet89
Re: festo solanoid
What we usually do is get a cup fill it with soapy water and get a small brush and brush the water on every fitting and connection where air might leak. This should help you find the leaks, it also might be the control valve that keeps the system from firing hire than 60 psi you might of hooked it up wrong.
Unread 03-02-2008, 10:57
GBIT's Avatar
GBIT GBIT is offline
Lexantologist/Team Lead
AKA: Jared
FRC #0811 (Cardinals)
GBIT is just really niceGBIT is just really niceGBIT is just really niceGBIT is just really niceGBIT is just really nice
Send a message via AIM to GBIT
Re: festo solanoid
yea do this the festo valves are made to be open at all times in ne position and only shift once power is supplied. It needs thirty PSI to do this though. so tie a really tight knot in two pieces of tubing. Plug those into the 2 and 4 ports on the festo valve plug your supply into one and leave three empty (exaust) then just let the pressure get above thirty then you will be able to shift.
-jared
-Mentor-
-WPI '13-
-Former Team Lead-
-Past Driver-
Unread 03-02-2008, 11:26
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is online now
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Re: festo solanoid
The compression fittings for tube insertion on the Festo valves need fairly straight tubing cuts. If you don't cut it straight, or you make 2 cuts to cut through the tubing, it'll leave enough of a gap when the tubing bottoms out in the compression fitting to leave an air path. Check your tubing to make sure that the cuts are good, if not cut it back a little and retry.
___________________
- Tennyson, Ulysses
Festo itay_ms Electrical 3 30-01-2007 09:08
Festo Single solenoid JP_1163 Pneumatics 4 24-02-2006 15:07
FESTO question evilhunter Programming 8 30-03-2005 15:47
festo solenoid maxgebhardt Pneumatics 19 21-01-2004 23:06
Festo Valve Gary Bonner Pneumatics 2 26-02-2002 17:48
