Go to Post You can't learn anything without breaking some stuff. - DonRotolo [more]
Unread 03-02-2008, 09:38
Boydean's Avatar
Boydean Boydean is offline
The Blue Alliance
Boydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant future
Send a message via AIM to Boydean
Re: 360 Degree Infrared Sensor Question
What is the possibly of pointing the IR board up and then putting some kind of reflector that points in from all angles.
Then again you can mount it on a motor and do it with software.
Unread 03-02-2008, 09:46
daviamp daviamp is offline
FRC #1254
daviamp will become famous soon enough
We have tried using a conical reflector, as found on a Roomba VirtualWall Unit, but distance was limited. We are thinking about using a sim motor and a radar like sweep to locate.
Thank You for your reply,
David Lamp
Senior Mentor
Team 1254
Unread 03-02-2008, 19:42
Shivang1923 Shivang1923 is offline
I make robot go VROOM VROOM!
FRC #1923 (MidKnight Inventors)
Shivang1923 has a spectacular aura aboutShivang1923 has a spectacular aura about
reflection wouldn't work right. you'd have a harder time aiming your remote to get around the non reflexive surface of your reflexive material (wow, mouthfull)
the sweeping idea is better because now it wont matter weather or not you are at one end of the field or the other.
Unread 05-02-2008, 10:28
FRC #1254
The sweeping idea is beginning to frustrate us, it seems that IR Remote Controls only send the device code once, when you orignally push the button, so as long as you push and hold the button and the remote control is in line of sight of the receiver, the robot gets signal, but as soon as the receiver loses signal from the IR Remote Control, by going out of line of sight, if you do not push the button again, the receiver does not know that you are sending the signal to it.
Unread 05-02-2008, 10:33
Miner Miner is offline
AKA: Jacob Miner
FRC #2077 (Laser Robotics)
Miner is on a distinguished road
We were going to try and see if we could use the gyro sensors to create a turret for the IR board. It is still being figured out but if you could get the board to point in the same direction for the 15 seconds that it is needed in the hybrid period, you should be able to keep in contact with the board.
Infrared Sensor Interface Problems jln646v Sensors 7 26-01-2008 13:37
Infrared sensor...receiver emayank Electrical 3 25-02-2005 19:54
Infrared Beacon and Sensor Diagnostics Code Released Kevin Watson Programming 3 25-02-2004 17:50
Warning: Error in infrared sensor construction document Kevin Watson Electrical 1 29-01-2004 19:28
360 degree pic of WILDSTANG archiver 2001 2 24-06-2002 01:31
