Go to Post There can never be enough recognition of a job well done. We can never say enough Thank You's. We can never measure the impact that an inspirational teacher or mentor can make on a student because it's priceless. - KathieK [more]
Unread 03-02-2008, 10:48
Danger in Disconnected IR Receiver
I've been concerned about the inherent dangers inadvertently introduced by Team Update #6's ruling that the IR Receivers must be physically disconnected from the robot while in the Pit.
The intent is admirable, however, the execution method is dangerous.
Every programmer should be aware that a physically disconnected IR Receiver will look to the code as if every IR command has been simultaneously selected.
The danger of course is that if your code simply checks to see if a pin is ==1, then you'll begin executing the first command you check. If you plan to use the IR in Teleop mode, then your robot will take off as soon as you turn it on in the pit. If you use IR only in Hybrid mode, then your robot will take off as soon as the Competition Port Auto switch is thrown.
Please design your code to check for and reject multiply selected IR commands.
P.S. And stand clear of the team in the next pit who won't test this ahead of time and will find out the hard way Thursday morning of the Regional.
Unread 03-02-2008, 10:54
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Re: Danger in Disconnected IR Receiver
I already made code that handles this well, and will blink the 4 red LEDs on the OI when the IR receiver is disconnected. I have posted this code in another thread, and have referred to it numerous times. It is really dangerous not to use some sort of safety code if the IR sensor becomes disconnected or it breaks. Here is my code I made:
//Variables should be declared at the beginning at the program
int mode = 0; //Set it to zero so the robot won't move!
int modea;
int irerror;
int errorloop;
//Switches off all the LEDs on the OI
Switch1_LED = 0;
Switch2_LED = 0;
Switch3_LED = 0;
Relay1_red = 0;
Relay2_red = 0;
Relay1_green = 0;
Relay2_green = 0;
Pwm1_green = 0;
Pwm2_green = 0;
Pwm1_red = 0;
Pwm2_red = 0;
/*The following code will check to make sure the IR sensor is not malfunctioning,
or it is not disconnected, as no more than one button can be triggered at a time.*/
mode = 0; //If there is no signal from the IR board later in the code, then disable the robot
irerror = 1;
if ((rc_dig_in03 + rc_dig_in04 + rc_dig_in05 + rc_dig_in06) < 3)
	irerror = 0; //Tells the disable program that there is no error detected
	if (rc_dig_in03 == 1)
		modea = 1;	//Set to Mode 1 (1st button)
	if (rc_dig_in04 == 1)
		modea = 2;	//Set to Mode 2 (2nd button)
	if (rc_dig_in05 == 1)
		modea = 3;	//Set to Mode 3 (3rd button)
	if (rc_dig_in06 == 1)
		modea = 0;	//EMERGENCY STOP (4th button)
	mode = modea;
//The following are the certain autonomous programs
//Each mode acts like a different program.
if (mode == 1) //Mode 1
	printf("Mode 1 %d\r");
	Switch1_LED = 1;
//Put your custom programming here, this will execute when the first button is pressed
if (mode == 2) //Mode 2
	printf("Mode 2 %d\r");
	Switch2_LED = 1;
//Put your custom programming here, this will execute when the second button is pressed
if (mode == 3) //Mode 3
	printf("Mode 3 %d\r");
	Switch3_LED = 1;
//Put your custom programming here, this will execute when the third button is pressed
//Leave the following code at the very end of the autonomous cycle, so it is sure to execute when and if it is needed.
if (mode == 0) //EMERGENCY STOP
	printf("Mode: Disabled %d\r");
	pwm01 = pwm02 = pwm03 = pwm04 = pwm05 = pwm06 = pwm07 = pwm08 = 127;
  	pwm09 = pwm10 = pwm11 = pwm12 = pwm13 = pwm14 = pwm15 = pwm16 = 127;
	relay1_fwd = relay1_rev = relay2_fwd = relay2_rev = 0;
	relay3_fwd = relay3_rev = relay4_fwd = relay4_rev = 0;
	relay5_fwd = relay5_rev = relay6_fwd = relay6_rev = 0;
	relay7_fwd = relay7_rev = relay8_fwd = relay8_rev = 0;
	//The following code shows all the red lights
	//on the OI to tell the drivers that the autonomous
	//has been disabled
	Pwm1_red = 1;
	Pwm2_red = 1;
	Relay1_red = 1;
	Relay2_red = 1;
	if (irerror == 1) //If the IR has an error, then flash
		printf("IR Sensor Problem, Check connection %d\r");
		errorloop++;
		if (errorloop > 5)
			Pwm1_red = 0;
			Pwm2_red = 0;
			Relay1_red = 0;
			Relay2_red = 0;
		if (errorloop > 9)
			errorloop = 0;
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 03-02-2008, 14:45
tseres's Avatar
tseres tseres is offline
obsessed with FIRST...
FRC #1565 (Think Tank Tech)
tseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of light
knowing about all the IR jamming etc, i'm almost thinking about not even using IR, but instead doing some kind of deak-reckoning autonomous code, where the IR only modifies what it does. Teams (IMHO) who are thinking of doing teleoperated-like handling with a TV remote should seriously reconsider. I can only imagine the damage some teams will cause because of a robot going out of control because another robocoach is on the same frequency and their robot picks it up....
Unread 03-02-2008, 15:27
Samuel H. Samuel H. is offline
Rookie Year: 1000
Samuel H. has a spectacular aura aboutSamuel H. has a spectacular aura about
Thank you for posting the code to help other teams. Just a quick quibble: the line 'printf("Mode 1 %d\r");' does not do what you want as there is no value to substitute for '%d'. You probably meant 'printf("Mode 1\r");'.
Thank you again and good luck.
Unread 05-02-2008, 22:05
RyanN's Avatar
RyanN
You're right... I'm still new to programming. It doesn't hurt the code at all to have it there, it will only clean it up by taking it out. Thanks for the suggestion.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Unread 05-02-2008, 22:09
blaxbb blaxbb is offline
Ohio State Engineering Scholar
AKA: Brian Barrett
FRC #2331
blaxbb is just really niceblaxbb is just really niceblaxbb is just really niceblaxbb is just really niceblaxbb is just really nice
wow nice catch
every team make sure you have safe code, so a robot doesn't go flying out of the pits (dragging the OI behind)
"Whether you think you can or think you can’t, you’re right." - Henry Ford
www.vthsrobotics.org
Unread 06-02-2008, 07:49
gnormhurst's Avatar
gnormhurst gnormhurst is offline
Norm Hurst
AKA: gnorm
#0381 (The Tornadoes)
gnormhurst will become famous soon enoughgnormhurst will become famous soon enough
I'm designing IR capability into the code but I'm not counting on it. The last time IR was involved in the game (2004) it was pretty much a failure. If I didn't see IR for another four years it would be okay with me.
Yes, pun intended.
Trenton Tornadoes 381
2004 Philadelphia Regional Winners
2006 Xerox Creativity Award
My corner of the USPTO.
My favorite error message from gcc: main is usually a function
My favorite error message from Windows: There is not enough disk space available to delete this file.
Unread 06-02-2008, 07:56
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Ditto on having it ready but not counting on it. I think it's going to be a bunch of jumbled IR by the time it reaches the robots with so many remotes/bright stage lights pointed all over the place. Ours stops working if we just shine a flashlight somewhere near it, let along one of those tens of spotlights FRC puts on the field. Also, if two remotes are pointed somewhere near the reciever, this also makes it stop working.
Putting a tube on it to confine the beam again renders it almost useless, since you have to have your robot essentially pointing right at you for it to work, and the point of the remote anyhow is to (perhaps) guide the robot back to straight from a misalignment... so you might not get any signal in the first place.
*sigh* but that's ok... that adaptive cruise control's starting to work miiiighty good....
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Reliable way to detect disconnected controller heydowns Control System 4 13-02-2007 08:30
Possible danger using default camera code Mike Programming 3 07-02-2006 23:28
Team in Danger! Jill1022 General Forum 36 13-01-2006 00:57
Please help a class in danger! MattK Chit-Chat 0 12-12-2005 20:40
FIRST in Danger Robocardgrl5 General Forum 49 29-07-2003 13:45
