Go to Post Your second year in FIRST is your first year as a mentor. - Jay Trzaskos [more]
Unread 28-01-2008, 09:28
schmidtz schmidtz is offline
FRC #2518
schmidtz is an unknown quantity at this point
Battery Charger
when using the one that came with the kit.... does it charge faster on the 6A setting because ive been using the 2A setting and it takes forevveerrrr
thanks mucho
Unread 28-01-2008, 09:47
Re: Battery Charger
The 6 amp setting is acceptable and recommended. Previous year's charger did not give you a choice, 6 amp was the only rate. However, no more than 6 ampsfor those of you trying to use other chargers.
Unread 31-01-2008, 18:52
robbrad robbrad is offline
FRC #1875 (Autonomato Autonomatons)
Team Role: Electrical
robbrad is an unknown quantity at this point
Re: Battery Charger
Yes, it charges faster at 6 amps.
Unread 31-01-2008, 20:12
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Battery Charger
High rate charging is not good for the health and longevity of the battery. Unlike a car battery, where the acid is liquid (and is more mobile) the gelled acid in these batteries doesn't move much, and therefore high charging rates do harm the battery. It is for that reason the FIRST limits which chargers you can use.
Unread 31-01-2008, 21:06
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
Re: Battery Charger
i haven't been able to get the new charger to finish a charge yet! I've let it "charge" for 24 hours and the charge indicator light only goes three high. I then take the the same battery, attach it to last years charger and it's fully charged in less than an hour.
Is anymore having the same issue?
Unread 31-01-2008, 21:15
Bluephlame's Avatar
Bluephlame Bluephlame is offline
Controls Leader
AKA: Joe B.
FRC #0145 (TRx)
Bluephlame is an unknown quantity at this point
Send a message via AIM to Bluephlame
Re: Battery Charger
Team 145 has found that 4A is the best level of charge for both battery health and charging speed.
<Patrician|Away> what does your robot do, sam?
<bovril> it collects data about the surrounding environment, then discards it and drives into walls.
Unread 31-01-2008, 22:43
Re: Battery Charger
Did you check that the charger is set for 12 volt battery and not the 6 volt setting.? If the 6 volt was selected it would give the condition you describe.
Unread 01-02-2008, 20:16
stuffssguy's Avatar
stuffssguy stuffssguy is offline
Team Captain
FRC #1258 (SeaLu Robotics)
stuffssguy is on a distinguished road
Re: Battery Charger
On our charger the 12V light doesn't light up.
Unread 03-02-2008, 11:22
Tottanka's Avatar
Tottanka Tottanka is offline
It isnt about bots,its about humans
AKA: Liron Gurvitz
FRC #3211 (The Y Team)
Tottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond repute
Re: Battery Charger
Does anyone know where can i get more of those chargers?
My FRC record: 10 Years,FTA (2008-9), 3 Teams(1947,2669,3211).3 RCA, 1 Championship EI(2016), 1 Divisional finalist (2016), 1 Regional winner.
Israeli 2016 Volunteer of the year.
Unread 03-02-2008, 11:27
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Battery Charger
One way to find where to buy something is to search for the part number in google.com
http://www.google.com/search?hl=en&q...=Google+Search
shows several sources.
New Battery Charger Don Wright Electrical 12 30-04-2008 15:46
backup battery charger falconmaster Electrical 16 22-01-2008 12:04
Battery Charger for long term battery care DougHogg Kit & Additional Hardware 0 08-02-2003 15:25
battery charger archiver 2001 3 23-06-2002 23:20
Battery Charger jgrater Kit & Additional Hardware 1 12-04-2002 14:14
