Go to Post I'm working, don't consume my oxygen. - DonRotolo [more]
Unread 03-02-2008, 14:25
Shivang1923 Shivang1923 is offline
I make robot go VROOM VROOM!
FRC #1923 (MidKnight Inventors)
Shivang1923 has a spectacular aura aboutShivang1923 has a spectacular aura about
Programing joystick buttons
Could someone please help me? I've been trying to figure out how to program the joystick buttons to make the motors move. I looked through the code samples, and the default code and I found nothing that I can understand properly.
My past experience with C is MikroC which is different than programing the FIRST FRC robots.
Thanks in advance!
Unread 03-02-2008, 14:30
psy_wombats's Avatar
psy_wombats psy_wombats is offline
AKA: A. King
FRC #0467 (Duct Tape Bandits)
psy_wombats has a spectacular aura aboutpsy_wombats has a spectacular aura aboutpsy_wombats has a spectacular aura about
Re: Programing joystick buttons
The joystick buttons should follow this sort of naming convention:
p1_sw_aux1
p1_sw_aux2
p1_sw_trig
p1_sw_top
Then just change the number of the port. You may want to look at ifi_frc.h. Everything's in there.
You should be able to work these with a simple if statement, something like:
if (p1_sw_aux1){
pwm01=255;
} else {
pwm01=127;
Unread 03-02-2008, 14:33
paulcd2000's Avatar
paulcd2000 paulcd2000 is offline
Accidentally speaks in C
AKA: Paul Dagnelie
FRC #1719 (The Umbrella Corp.)
paulcd2000 is a jewel in the roughpaulcd2000 is a jewel in the roughpaulcd2000 is a jewel in the rough
Send a message via AIM to paulcd2000
there's also of course the joystick values themselves (p1_y, p1_x, p2_y...), and the wheel values (p1_wheel) (look on other threads for the output)
"People don't say 'It's just a game' when their team is winning!" -- Scott Adams
5.5 students (on average)* $7/h *210 hours/student= $8085 of labor, all volunteered (not counting mentors', who are each that much)
We have blades on our robot?! ***sweeeeeet***
There are 11 types of people in the world. Those who can read binary, those who can't, and those who say this joke is supposed to be, "There are 10 types of people in the world. Those who can read binary and those who have a life."
Unread 03-02-2008, 14:37
tseres's Avatar
tseres tseres is offline
obsessed with FIRST...
FRC #1565 (Think Tank Tech)
tseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of light
ok, i'll assume you're using port 1 on the operator interface (OI). just because i'm not sure what you know up to this point (and who's reading) i'll just give a brief intro.
as you know, the port your joystick is plugged into is referrred to as pX_something, so it will be p1_.....
the analog outputs are
p1_y, the y-axis,
p1_x, the x-axis,
p1_wheel, p1_aux ...these are not used as far as i know on the KOP joysticks (possibly the hat on the top?), but they ARE used with the USB ckicklet if you're using that....
now, the analog buttons are:
p1_sw_trig, the trigger,
p1_sw_top, one of the buttons, i'm not sure which, as with
p1_sw_aux1 and p1_sw_aux2.
that's about it!
Unread 03-02-2008, 19:14
ShotgunNinja's Avatar
ShotgunNinja ShotgunNinja is offline
Programming Mentor, FRC 4247
AKA: Nicholas Iannone
FRC #4247 (CougarBOTS)
ShotgunNinja is a jewel in the roughShotgunNinja is a jewel in the roughShotgunNinja is a jewel in the roughShotgunNinja is a jewel in the rough
Are you using a Robotics IDE (ROBOTC, EasyC, etc.), or are you using a regular C editor? I've found EasyC to be just that, easy. If you are this early on in the programming, you can still switch over to EasyC (or another), and have that much already taken care of for the programming, so you can focus on other things like figuring out the best way to pull off Hybrid Mode.
In EasyC, you could do it in about 6 lines of code.
EDIT: By the way, yes; the p1_wheel does refer to the "hat", and I believe that there is also p1_sw_thumb for the thumb button (or would that be what p1_sw_top goes to?)
Team #2970 Alum
Team #1652 Alum
2006: School Mascot for Team 1652
2007-2008: Programmer for Team 1652 (Robot Mafia)
2009: Programmer on Team 1652 (Robot Mafia), Programmer on Team 2970 (eSchool eBots)
2010-2016: Volunteer, Wisconsin Regional
2017: Programming Mentor, FRC 4247 (CougarBOTS, Obama SCTE, Milwaukee, WI)
Unread 03-02-2008, 19:22
in between teams
AKA: Luke Van Oort
I'm surprised it takes that much. In MPLAB, it is just four:
if(p1_sw_top)
   pwm01 = 254;
else
   pwm01 = 127;
or five:
if(p1_sw_top){
   pwm01 = 254;
} else {
   pwm01 = 127;
depending on your coding styles.
p1_sw_top is the top button on CH flightsticks and, I believe, one of the buttons on the top of the AVB Top Shots. I think the thumb button is either another trigger or top button... the wiring in those AVB sticks is darn confusing.
Team 1219: 2009 - Mentor
Unread 03-02-2008, 19:47
Well, actually, we're using two AVB (or is it ADB? It looks kind of like that ) sticks for our OI, and using EasyC for programming, we don't need to use the p1_sw_(fill in the blanks) variables, as we can just use a single function to bind everything together. It hurts my pride acquired from slaving over the Source Engine code to use such simplified functions, thus limiting my amount of precise control, but it goes a lot faster, and it works.
EDIT: And those six lines set up the entire operator interface. Just a by-the-way.
Team #2970 Alum
Team #1652 Alum
Unread 03-02-2008, 20:46
if(p1_sw_top)
   pwm01 = 254;
else
   pwm01 = 127;
or five:
if(p1_sw_top){
   pwm01 = 254;
} else {
   pwm01 = 127;
I can name that tune in one note...I mean, I can write that function in one line:
  pwm01 = p1_sw_top?254:127;
Anyway, Shivang, if you give some more detail about what you want to accomplish, we can give better advice. Which buttons do you want to use, and what do you want the motors to do when you use them?
Unread 09-02-2008, 16:21
program1's Avatar
program1 program1 is offline
AKA: RJ
FRC #2441
program1 will become famous soon enough
it mostly depends on which controler you are using, if your using controler 1:
p1_sw_trig
p1_sw_top
p1_sw_aux1
p1_sw_aux2
to program the buttons is acutally very simple
pwm01 = 127
if (p1_sw_trig == 1)
{pwm01 = 150}
this program says "while controler 1's trigger is being pressed, pwm01 will move at 150"
this is the way i was taught anyway, the other ways will work also
ok, who ate my hot pocket?
Buttons to Pins on Joystick yarb65 Electrical 1 24-08-2007 20:39
Programming Extra Joystick Buttons Inverted Programming 2 08-02-2007 11:45
Victors Controlled By Joystick Buttons douglass1371 Electrical 2 17-02-2006 01:57
Programing a joystick Justin_302 Programming 2 21-03-2005 22:45
Assigning Joystick buttons.... archiver 2001 5 24-06-2002 00:59
