Go to Post One wondered why they couldn't practice in the gym that day - because the robotics team had it reserved was the answer. "Oh, we have a robotics team?" Sigh. This is a team with a low number. They've been around for at least a dozen years. There's still a lot more culture-changing to do. - GaryVoshol [more]
Unread 03-02-2008, 16:01
PlaidPillagers's Avatar
PlaidPillagers PlaidPillagers is offline
FRC #2538 (Plaid Pillagers)
PlaidPillagers is an unknown quantity at this point
12 volt battery position
Morris Team 2538 Plaid Pillagers are asking you:
Do your batteries have to be positioned vertically? Or is it possible to position them horizontally? Thanks!
Unread 03-02-2008, 16:02
Re: 12 volt battery position
No rules govern position or orientation of batteries. The only thing limiting placement is the length of the cables.
Unread 03-02-2008, 16:05
Morris Team 2538 Plaid Pillagers:
Thanks for the clarification.
Unread 03-02-2008, 17:31
Al Skierkiewicz Al Skierkiewicz is online now
You may mount either battery in any configuration. It is recommended, however, not to charge the battery upside down. I tell folks not to mount the battery upside down in the robot since it makes it easir for the terminals to come in contact with the robot frame.
Unread 03-02-2008, 19:02
ebarker's Avatar
ebarker ebarker is offline
AKA: Ed Barker
FRC #1311 (Kell Robotics)
ebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond repute
Just to elaborate on Al's comments.
Make sure the terminals are insulated with multiple wraps or tape or use heat shrink tubing. Absolutely prevent the terminals from contacting the metal frame. It makes a big mess !!
Ed Barker
Unread 03-02-2008, 19:39
Shivang1923 Shivang1923 is offline
I make robot go VROOM VROOM!
FRC #1923 (MidKnight Inventors)
Shivang1923 has a spectacular aura aboutShivang1923 has a spectacular aura about
we have ours mounted vertically but that's just because of room issues. Personally, I would've gone with vertical anyways. You can have a lot more support to stop the battery from popping out than horizontally.
Unread 03-02-2008, 21:17
Sam N.'s Avatar
Sam N. Sam N. is offline
FRC #1351 (TKO)
Sam N. is a splendid one to beholdSam N. is a splendid one to beholdSam N. is a splendid one to beholdSam N. is a splendid one to beholdSam N. is a splendid one to beholdSam N. is a splendid one to beholdSam N. is a splendid one to behold
Send a message via AIM to Sam N.
We did some research on this.
You may position your battery either way - the rules allow any orientation.
The quality of the battery is not affected in anyway between vertical positioning and horizontal. That's output quality when the battery is being used.
Thanks for the warning about not charging upside down though, we didn't come across anything about re-charge.
Sam
Mitty Robotics Alumni
TKO 1351
Unread 03-02-2008, 22:39
DonRotolo's Avatar
Back to humble
FRC #0832
The reasoning behind that is that there's a safety valve in there, which you cannot see, but it is located on top. If the valve goes off (which is rare anyway) with the valve on the bottom, you can spew gelled acid. No reason to charge it upside down, so prevent that accident before it happens.
Don
Unread 03-02-2008, 22:55
Sunshine's Avatar
Sunshine Sunshine is offline
Mr. S
FRC #2062 (C.O.R.E)
Sunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to behold
Really?
That's the first I have ever heard of a safety valve in batteries. Care to share your source?
It's true, even I can learn something new every day
C.O.R.E. Community Of Robotic Engineers
2015 Wisconsin Regional Champs, Safety Award
2015 Midwest Regional Champs, Safety Award, Industrial Controls Award
2014 Midwest Regional Judges Award
2013 Lake Superior Champs
2012 World Championship Safety Award, World Finalist for the Autodesk Award
2011 Wisconsin Regional - Website Award 10,000 Lakes - Innovation in Control, Safety Award
2010 World Championship - Archimedes Semi-Finalists -World Finalist for the Autodesk Award
2010 10,000 Lakes Regional Champs, Entrepreneurship Award; Wisconsin Regional- Entrepreneurship Award, Safety Award
2009 WI Regional- Quality Award, Safety Award 10,000 Lakes - Safety Award, Motorola Quality Award, Animation Award
2008 World Championship Safety Award
2008 Wisconsin Regional Champs, Safety Award
2008 St. Louis Regional Entrepreneurship Award, Safety Award, Website Award
2007 Wisconsin Regional All-Star Rookie Award
Unread 03-02-2008, 23:11
ebarker's Avatar
AKA: Ed Barker
Just google around and find an explanation of how gel-cels works. Johnson Controls probably has one. There is a wiki below. These gel cells are a modern variation of the lead- liquid acid battery that goes back to the telegraph era of the 1800's. And is used in your car.
It is possible for the gel-cell to create hydrogen gas just like their liquid counterparts. go here and search for 'gas' http://en.wikipedia.org/wiki/Battery_(electricity)
Ed Barker
Unread 03-02-2008, 23:25
AKA: Dr. Brooks
no team (WRRF)
Originally Posted by Sunshine View Post
Really?
http://en.wikipedia.org/wiki/Lead-ac...acid_batteries
Unread 04-02-2008, 07:34
If you examine your battery, you will see a small insert about 3/4" wide running across the top of the battery. The safety valves live underneath that insert, one for each of the six cells. During charging, in particular, heat can be generated within each cell as well as a little gas. The valve is in place should the pressure build to a point where the case could be compromised. Should the battery encounter one of these "high pressure" episodes in the inverted position, some electrolyte could be expelled. This is a rare event but it is simply remedied by charging in the "terminals up" orientation. These batteries also make some water vapor during high current charge/discharge cycles that may also vent through the valves. As more water is lost, battery capacity will be reduced. Our batteries are of the AGM (absorbed glass mat) gelled design. So when researching batteries, some of the info on gel cell batteries may not fully apply to the batteries we use. AGM batteries are less suscpetible to some of the events described above in comparison with the standard gel cell variety.
Unread 04-02-2008, 09:48
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Shown here, during an "impact test" at high speeds.
http://www.chiefdelphi.com/media/photos/19280
Unread 06-02-2008, 19:18
TheNotoriousKid's Avatar
TheNotoriousKid TheNotoriousKid is offline
AKA: Shane O
FRC #0025 (Raider Robotix)
TheNotoriousKid is just really niceTheNotoriousKid is just really niceTheNotoriousKid is just really niceTheNotoriousKid is just really niceTheNotoriousKid is just really nice
Send a message via AIM to TheNotoriousKid
I don't know of any restrictions, but you should think logical about your placement, connectors, and this year where the ball will be in comparison to your robot. Like if the trackball is gonna' have to sink into your bot, then ur battery should probably be laid down...etc.
MK 12 volt battery question Seki Electrical 54 03-03-2007 02:09
12 Volt Battery Substitute maniac_2040 Electrical 6 21-01-2007 00:43
7.2 Volt Battery Justin_302 Electrical 4 28-01-2005 23:25
24 Volt Solenoid? Stephen Kowski Pneumatics 2 27-01-2005 11:44
6 Volt charger...? kangarue23 Technical Discussion 7 12-04-2002 10:35
