Go to Post I guess the freshmen had to learn the hard way, never turn your back on a robot. - Bcahn836 [more]
Unread 03-02-2008, 15:06
DanaRocks's Avatar
DanaRocks DanaRocks is offline
FRC #2220 (Blue Twilight)
DanaRocks is an unknown quantity at this point
pic: 2220 Drive Train! What do you think?
Unread 03-02-2008, 15:08
nittemare nittemare is offline
nittemare
FRC #1516 (Grizzlies)
nittemare is an unknown quantity at this point
Re: pic: 2220 Drive Train! What do you think?
If you guys are using high traction wheels with omni's in the back your gonna have some serious problems turning. We did the same thing and if you just tap the joysticks to turn it will do a 180 degree drift.
Unread 03-02-2008, 16:48
umtymp5200's Avatar
umtymp5200 umtymp5200 is offline
AKA: Cory
FRC #2545 (High Jumps)
Team Role: Student
umtymp5200 is an unknown quantity at this point
This drive train works if you use a rear-wheel drive system. It gets rid of the "drifting" problem.
Unread 03-02-2008, 17:09
llama llama is offline
AKA: Michael Goelz
FRC #2077 (Kettle Moraine Robotics/Laser Robotics)
llama is an unknown quantity at this point
Send a message via AIM to llama
idk what you guys are talking about... wee used this last year and it worked great and (dispite my preference to holomonic drive systems) we are using it again this year. If you have trouble with drifting with the omnis then either
A.) stop using 1 joystick
B.) make the rollers slower (dust works pretty well as we found out)
Unread 03-02-2008, 17:15
RoboGeek99's Avatar
RoboGeek99 RoboGeek99 is offline
FRC #2582 (Panther Bots)
RoboGeek99 is just really niceRoboGeek99 is just really niceRoboGeek99 is just really niceRoboGeek99 is just really nice
From the picture the chain seems pretty lose, if you have lost the chain at all you need to seriously consider making so tensioners in order to not have that problem from competition. As for the drifting i dont know anything on that matter because im in a rookie team and we didnt even consider omni wheels
Unread 03-02-2008, 17:31
KTorak's Avatar
KTorak KTorak is offline
Fire Rescue 47
AKA: Kyle Dersch
FRC #1023 (Bedford Express)
Team Role: Driver
KTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond repute
Send a message via AIM to KTorak
We have also used drive systems in the past with omni wheels in the back and regular pneumatic wheels in the front that are powered. It actually makes it maneuver pretty well.
Kyle D- Myspace - Facebook
2008 Bedford Express Driver & Build & Design (Team) Co-Leader
2007 Bedford Express Driver & Build & Design (Team) Leader
2006 Bedford Express Driver, Build Team Member, & Board of Directors
2005 Bedford Express Rookie, Build Team Member & Robot Operator
2008 - GLR Quarter Finalist
2007 - GLR Finalist & Boilermaker Finalist & MARC Off Season Event Winner
2006 - GLR Johnson & Johnson Sportsmanship Award & Archimedes 7th Seed Quarter Finalist
2005 - GLR Finalist & Judges Award.
2004 - GLR Semi Finalist.
2003 - GLR/DTR Quarter Finalist & GLR/NAT'L Rookie All Star.
Unread 03-02-2008, 17:36
DarkFlame145 DarkFlame145 is offline
That guy
AKA: Dennis
no team (None this season)
DarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud of
Send a message via AIM to DarkFlame145
Indeed that chain is going to hit that 1/2 inch bump in the field
TR-X 145 of Norwich, NY: Student 2005-2008
Exploding Bacon 1902 of Winter Park, FL: Mentor 2009
US Navy Corpsman 2011-????
Unread 03-02-2008, 17:55
Matt382 Matt382 is offline
Driver/Drivetrain Subteam Leader
FRC #1816 (The Green Machine)
Team Role: Driver
Matt382 has a spectacular aura aboutMatt382 has a spectacular aura aboutMatt382 has a spectacular aura about
As far as chain tensioners, we found some easy to mount ones at www.mcmaster.com. They are called floating roller chain tensioners. So far in practice they seem to be doing really well.
What type of drive train did you make this year? James114 Technical Discussion 31 12-03-2005 19:11
pic: what do you think? CD47-Bot Robot Showcase 27 21-04-2004 10:38
2002 drive-train: Who do you think was the best? Jessi Technical Discussion 14 25-10-2002 15:54
