Go to Post The robot is never 'done' there is always something that can be done to improve it. - Jonathan Norris [more]
Unread 03-02-2008, 22:21
captainking's Avatar
captainking captainking is offline
Level 85 Programmer
FRC #0168 (MIB)
captainking is an unknown quantity at this point
resistors
I felt this should go in chit-chat because most FIRST robots don't deal with micro electronics,
a team member and me are doing a little side project while we build the robot that calls for a 20K resistor, sadly the only thing I have close to that is a a few 10K resistors, if I strung them together would it suffice? is there any method of combining resistors to combine their resistance?
Unread 03-02-2008, 22:30
Back after 4 years off
FRC #5279
Re: resistors
Resistance adds in series. If you connect 2 10k resistors in series it is the same as 1 20k resistor.
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Unread 03-02-2008, 22:31
DonRotolo's Avatar
Back to humble
FRC #0832
Re: resistors
...so two 10k resistors can be combined to make 20k.
Unread 04-02-2008, 10:04
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
Re: resistors
Yes, 2 10K resistors in series, one after the other, is 20K
2 10K resistors in parallel, is 5K
HTH
DIP/SIP resistors John Gutmann Electrical 9 26-08-2005 20:27
LED's, resistors, computers... ohm my! DanL Electrical 3 01-07-2003 09:37
Internal Fuses (PTC Resistors) on Window Motors bigqueue Technical Discussion 6 08-02-2002 21:34
