| My love for you never slides around. |
#16
Re: Best way to remove fisher price pinion???
How do you hold the pinion gear when pressing the gear off?
#17
I used a hammer and cold chisel, split the gear in half lengthwise, very quick and easy. Support the gear on a big chunk of solid metal like the anvil part of a bench vice or a heavy welding table, put the chisel in the space between the two topmost teeth, and give it a good whack with a big hammer.
Needless to say the gear will not be useable after this operation. |
#18
See my previous post in this thread with the picture of the plate. Best way we've found to hold it.
#19
OHHH I just did this yesterday for the first time xD
So... We made a plate that fit on the shaft under the pinion. We cut that little plastic spacer off. A 1/8" Steel plate w/ a slot went right in. We put another plate in, and used a shop press to press the motor off the pinion. |
#20
We have a fixture that we use. I can post a picture of it tomorrow.
#21
With that being said, I will join the others who used a nutsplitter - they're wonderful. |
#22
Squirrel: Your solution as well as the nut breaker would work. We'll need to do the same thing with an RS550 motor and plan to reuse that pinion, so need to have a way to remove them without destroying them. By nature I am a pack-rat and it seems like somewhere/sometime we'll have a need for a 19 tooth gear (I have boxes of this kind of stuff), so I'll advise not destroyinng it. Thanks to all for the flurry of responses. I'll offer these as suggestions to the team and let them decide how they want to do it. Martin ![]() |
#23
Here are the pictures of what we use to take the fisher price pinions off with. We made this out of aluminum.
#24
That's a very nice gear puller!
#25
Very nice! What's the thickness of the part that goes under the actual pinion? And I assume you guys have an arbor press as well? Or would a drill press work with this tool?
#26
We do use an arbor press. A drill press is not a very good option unless it's last resort. The actual part that goes under the pinion is made of steel(unlike what I said earlier) and the rest is made of aluminum(like I said earlier). The actual thickness that goes under the pinion is 0.085". This works really well for us.
| Fisher-Price 00968-9012 motor pinion | Joe P | Motors | 3 | 03-04-2007 19:31 |
| fisher-price pinion gear | bill mc gowan | Motors | 6 | 06-03-2006 11:14 |
| Fisher Price Pinion Pressure Angle | alphastryk | Motors | 1 | 04-02-2006 21:06 |
| Fisher Price Gearboxes | Nathan Pell | Motors | 7 | 06-03-2004 11:29 |
| Legal way to remove bottles? and other questions | jrukes | Off-Season Events | 4 | 15-10-2001 22:35 |
