Go to Post Honestly, I always thought that the true meaning for nerd was an intellectual badass. - rcmolloy [more]
Unread 03-02-2008, 23:35
Gdeaver Gdeaver is offline
FRC #1640
Re: pic: 1726 week 4
Why the AL frame. You're using poltrusion below. Why not continue with the uper frame?
Unread 03-02-2008, 23:37
Matt H. Matt H. is offline
Long Distance Mentor
FRC #1726 (N.E.R.D.S.)
Matt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond repute
The Al is for mounting the mechanism on it--it save weight (lots) and is easier to machine than pultrusion. Pultrusion must also be thicker to achieve the same strength as aluminum so it would be unwieldy to mount that way.
Unread 03-02-2008, 23:39
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
or, the short answer: we had the pultruded fiberglass channel for the frame already, but no thin angle, so we went with aluminum. Also the aluminum is available at Ace hardware, and easy to replace if it we have problems with it in competition.
Unread 03-02-2008, 23:42
CCCP's Avatar
CCCP CCCP is offline
stanislav Sekacov
AKA: The Russian
CCCP will become famous soon enoughCCCP will become famous soon enough
our bot is so cool
Unread 03-02-2008, 23:45
BHS_STopping's Avatar
BHS_STopping BHS_STopping is offline
The Freshman
FRC #0842 (Falcon Robotics)
BHS_STopping has a brilliant futureBHS_STopping has a brilliant futureBHS_STopping has a brilliant futureBHS_STopping has a brilliant futureBHS_STopping has a brilliant futureBHS_STopping has a brilliant futureBHS_STopping has a brilliant futureBHS_STopping has a brilliant futureBHS_STopping has a brilliant futureBHS_STopping has a brilliant futureBHS_STopping has a brilliant future
Originally Posted by CCCP View Post
our bot is so cool
I'm sure the rest of the team is proud of it too, Stan.
[/The Freshman]
Unread 04-02-2008, 00:09
Amir's Avatar
Amir Amir is offline
FRC #1717 (dpengineering)
Amir is a splendid one to beholdAmir is a splendid one to beholdAmir is a splendid one to beholdAmir is a splendid one to beholdAmir is a splendid one to beholdAmir is a splendid one to beholdAmir is a splendid one to beholdAmir is a splendid one to behold
Is the tensioner an off the shelf item or machined from a piece of round stock? If it is off the shelf where did you get it? If not what material is it, HMWPE or Nylon? We are looking for a new/easier tensioning system and we have been leaning toward the off-center circle. I would also like to know what materials work best for this method.
Thanks,
Amir
Unread 04-02-2008, 00:13
MrForbes's Avatar
AKA: Jim
We made the green tensioners with oil impregnated nylon rod (2" diameter), turned on the lathe.
The white material (UHMW Polyethylene) that the chain guide is made of would work well too, I suppose...we had the nylon rod left over from last year, so we made the tensioners with it.
Also we added an internal/external tooth lockwasher between the tensioner and frame rail to make sure it would not slip.
GUI GUI is offline
AKA: Gary
FRC #4183 (Bit Buckets)
GUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to behold
Send a message via Yahoo to GUI
Nevermind, Mr. Forbes beat me to it!
Unread 04-02-2008, 00:14
The tensioner is nylon because it tends to self lubricate as it wears away. The piece was machined on a lathe--it was simply a matter of cutting away a little from each side of a thin piece leaving a small runner to guide the chain (you could also cut a groove)--I'll see if I can get some more detailed picture later.
We have been using nylon for tensioners since last year and have little visible wear on it even after two regionals.
Unread 04-02-2008, 00:22
Amir's Avatar
We have used the nylon spring-loaded ones from McMaster and it is kind of clunky and hard to incorporate into the chassis.
Can you tell me which nylon round stock you used? I don't need a picture but others may benefit from one.
Thanks
Amir
Unread 04-02-2008, 00:23
GUI GUI is offline
AKA: Gary
I believe it was McMaster part # 8664K15
Unread 04-02-2008, 00:24
Do a mcmaster search for oil-filled nylon rods I believe we used either the 1 1/2in or the 2 in rod.
Unread 04-02-2008, 00:34
Amir's Avatar
Do you know if the oil-filled nylon is better than the oil-filled UHMWPE, part number 5243T23? The reason I ask is that the chain guides you are using are made from UHMWPE not nylon.
Unread 04-02-2008, 00:36
GUI GUI is offline
AKA: Gary
When playing with the chain, the UHMWPE seemed to be a little more slippery. We used the nylon because we already had it, if I was ordering material for the tensioners i would go for the UHMWPE.
Unread 04-02-2008, 00:25
MrForbes's Avatar
AKA: Jim
McMaster part number 8664K15 is enough to last for a few years
pic: 1726 Promobot GUI Extra Discussion 18 01-11-2007 18:04
pic: 1726 NURC ROV s_forbes Extra Discussion 11 13-06-2007 23:54
pic: 1726 2007 OI TheOtherGuy Extra Discussion 2 11-02-2007 23:17
pic: 1726 Unfinished Parts MrForbes Extra Discussion 6 26-01-2007 00:14
pic: Real Pic of Team 1726 MegaMaid Progress yodameister Extra Discussion 4 12-02-2006 13:23
