Go to Post "What other program puts these role models on a first name basis with teenagers?" - Andy Baker [more]
Unread 03-02-2008, 22:43
TheOtherGuy's Avatar
TheOtherGuy TheOtherGuy is offline
Unregistered User
AKA: Kevin Forbes
FRC #4183 (Bit Buckets)
TheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond repute
pic: 1726 week 4
Unread 03-02-2008, 22:44
DarkFlame145 DarkFlame145 is offline
That guy
AKA: Dennis
no team (None this season)
DarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud of
Send a message via AIM to DarkFlame145
Re: pic: 1726 week 4
Very cool looking, I like the chain system on it.
TR-X 145 of Norwich, NY: Student 2005-2008
Exploding Bacon 1902 of Winter Park, FL: Mentor 2009
US Navy Corpsman 2011-????
Unread 03-02-2008, 22:51
falconmaster's Avatar
falconmaster falconmaster is offline
AKA: Ledge
FRC #0842 (Falcon Robotics)
falconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond repute
Send a message via MSN to falconmaster
You beat us on the chassis weight, we were 70-75!
Faridodin "Fredi" Lajvardi KD7WKD
Unread 03-02-2008, 23:24
AdamHeard's Avatar
Lead Mentor
Why not use two idlers rather than the curved plastic? It'd be a lot more efficient.
Unread 03-02-2008, 23:26
Unregistered User
AKA: Kevin Forbes
The green plastic is our tensioner. The hole is off center, so we just loosen it and rotate it to tension the chain.
Unread 03-02-2008, 23:27
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
I'm curious how we'd calculate the efficiency of it either way...any ideas?
Unread 03-02-2008, 23:29
GUI GUI is offline
AKA: Gary
GUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to behold
Send a message via Yahoo to GUI
The curved plastic is UHMW Polyethylene chain guide from McMaster. It is very light and has very little friction on the chain. Using idlers would have placed the top length of the chain a lot higher up from the frame, and would have been very difficult to mount.
Unread 03-02-2008, 23:30
Matt H. Matt H. is offline
Long Distance Mentor
Matt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond repute
I'd say the efficiency loss due to friction on the plastic is minimal and worth the benefit of not having to make very precise holes for idlers. As a general team moto the less machining the better.
Unread 03-02-2008, 23:35
Gdeaver Gdeaver is offline
FRC #1640
Why the AL frame. You're using poltrusion below. Why not continue with the uper frame?
Unread 03-02-2008, 23:37
The Al is for mounting the mechanism on it--it save weight (lots) and is easier to machine than pultrusion. Pultrusion must also be thicker to achieve the same strength as aluminum so it would be unwieldy to mount that way.
Unread 03-02-2008, 23:39
MrForbes's Avatar
AKA: Jim
or, the short answer: we had the pultruded fiberglass channel for the frame already, but no thin angle, so we went with aluminum. Also the aluminum is available at Ace hardware, and easy to replace if it we have problems with it in competition.
Unread 03-02-2008, 23:40
AKA: Ledge
Yes! As a pioneer of Pultruded Fiberglass in FIRST I would like to know why too!
Unread 03-02-2008, 23:42
CCCP's Avatar
CCCP CCCP is offline
stanislav Sekacov
AKA: The Russian
CCCP will become famous soon enoughCCCP will become famous soon enough
our bot is so cool
Unread 03-02-2008, 23:44
MrForbes's Avatar
AKA: Jim
We like to play around with different materials, finding the best material for each part, kind of as an engineering exercise. A lot of that has to do with the equipment we have available in the shop, time needed to order materials and build parts, as well as the loading on each part. I think fiberglass is really excellent for frames, but it is a bit more tricky to use it in the upper parts of the robot, and we haven't gotten good enough at designing with it yet to feel confident using it there.
Unread 03-02-2008, 23:45
BHS_STopping's Avatar
BHS_STopping BHS_STopping is offline
The Freshman
BHS_STopping has a brilliant futureBHS_STopping has a brilliant futureBHS_STopping has a brilliant futureBHS_STopping has a brilliant futureBHS_STopping has a brilliant futureBHS_STopping has a brilliant futureBHS_STopping has a brilliant futureBHS_STopping has a brilliant futureBHS_STopping has a brilliant futureBHS_STopping has a brilliant futureBHS_STopping has a brilliant future
Originally Posted by CCCP View Post
our bot is so cool
I'm sure the rest of the team is proud of it too, Stan.
[/The Freshman]
pic: 1726 Promobot GUI Extra Discussion 18 01-11-2007 18:04
pic: 1726 NURC ROV s_forbes Extra Discussion 11 13-06-2007 23:54
pic: 1726 2007 OI TheOtherGuy Extra Discussion 2 11-02-2007 23:17
pic: 1726 Unfinished Parts MrForbes Extra Discussion 6 26-01-2007 00:14
pic: Real Pic of Team 1726 MegaMaid Progress yodameister Extra Discussion 4 12-02-2006 13:23
