Go to Post It's ok to be tired. That's what CD Mods are for. - Jessica Boucher [more]
Unread 03-02-2008, 23:53
falconmaster's Avatar
falconmaster falconmaster is offline
AKA: Ledge
FRC #0842 (Falcon Robotics)
falconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond repute
Send a message via MSN to falconmaster
Re: pic: 1726 week 4
Originally Posted by squirrel View Post
We like to play around with different materials, finding the best material for each part, kind of as an engineering exercise. A lot of that has to do with the equipment we have available in the shop, time needed to order materials and build parts, as well as the loading on each part. I think fiberglass is really excellent for frames, but it is a bit more tricky to use it in the upper parts of the robot, and we haven't gotten good enough at designing with it yet to feel confident using it there.
Ok we will let is slide this time, because it does look cool! We haven't seen a 3 inch c channel before. It looks "mini"!
Faridodin "Fredi" Lajvardi KD7WKD
Unread 03-02-2008, 23:56
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
It's actually 4" C channel on the frame. Gary did most of the chassis design on Inventor. Also our promobot we built in the fall used fiberglass for all the structural parts, so we are playing around with it a bit. Time to order more, though
Unread 04-02-2008, 00:09
Amir's Avatar
Amir Amir is offline
FRC #1717 (dpengineering)
Amir is a splendid one to beholdAmir is a splendid one to beholdAmir is a splendid one to beholdAmir is a splendid one to beholdAmir is a splendid one to beholdAmir is a splendid one to beholdAmir is a splendid one to beholdAmir is a splendid one to behold
Is the tensioner an off the shelf item or machined from a piece of round stock? If it is off the shelf where did you get it? If not what material is it, HMWPE or Nylon? We are looking for a new/easier tensioning system and we have been leaning toward the off-center circle. I would also like to know what materials work best for this method.
Thanks,
Amir
Unread 04-02-2008, 00:13
MrForbes's Avatar
AKA: Jim
We made the green tensioners with oil impregnated nylon rod (2" diameter), turned on the lathe.
The white material (UHMW Polyethylene) that the chain guide is made of would work well too, I suppose...we had the nylon rod left over from last year, so we made the tensioners with it.
Also we added an internal/external tooth lockwasher between the tensioner and frame rail to make sure it would not slip.
GUI GUI is offline
AKA: Gary
FRC #4183 (Bit Buckets)
GUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to behold
Send a message via Yahoo to GUI
Nevermind, Mr. Forbes beat me to it!
Unread 04-02-2008, 00:14
Matt H. Matt H. is offline
Long Distance Mentor
Matt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond repute
The tensioner is nylon because it tends to self lubricate as it wears away. The piece was machined on a lathe--it was simply a matter of cutting away a little from each side of a thin piece leaving a small runner to guide the chain (you could also cut a groove)--I'll see if I can get some more detailed picture later.
We have been using nylon for tensioners since last year and have little visible wear on it even after two regionals.
Unread 04-02-2008, 00:22
Amir's Avatar
We have used the nylon spring-loaded ones from McMaster and it is kind of clunky and hard to incorporate into the chassis.
Can you tell me which nylon round stock you used? I don't need a picture but others may benefit from one.
Thanks
Amir
Unread 04-02-2008, 00:23
GUI GUI is offline
AKA: Gary
I believe it was McMaster part # 8664K15
Unread 04-02-2008, 00:24
Do a mcmaster search for oil-filled nylon rods I believe we used either the 1 1/2in or the 2 in rod.
Unread 04-02-2008, 00:25
MrForbes's Avatar
AKA: Jim
McMaster part number 8664K15 is enough to last for a few years
Unread 04-02-2008, 00:32
Aren_Hill's Avatar
Build Nifty Things
i have to say i do like the pulltrusion shape that easily makes what would've taken multiple pieces of other materials to make. And it would've most likely ended up heavier.
looks like a great drive base, how much did you lower the center wheel?
A guy who likes robots.
Unread 04-02-2008, 00:34
Amir's Avatar
Do you know if the oil-filled nylon is better than the oil-filled UHMWPE, part number 5243T23? The reason I ask is that the chain guides you are using are made from UHMWPE not nylon.
GUI GUI is offline
AKA: Gary
Center wheel is lowered 1/8"
Unread 04-02-2008, 00:35
We used the nylon because we had it on hand--Either should work well.
Unread 04-02-2008, 00:36
GUI GUI is offline
AKA: Gary
When playing with the chain, the UHMWPE seemed to be a little more slippery. We used the nylon because we already had it, if I was ordering material for the tensioners i would go for the UHMWPE.
pic: 1726 Promobot GUI Extra Discussion 18 01-11-2007 18:04
pic: 1726 NURC ROV s_forbes Extra Discussion 11 13-06-2007 23:54
pic: 1726 2007 OI TheOtherGuy Extra Discussion 2 11-02-2007 23:17
pic: 1726 Unfinished Parts MrForbes Extra Discussion 6 26-01-2007 00:14
pic: Real Pic of Team 1726 MegaMaid Progress yodameister Extra Discussion 4 12-02-2006 13:23
