Go to Post I owe it to the FIRST community and the awesome users of this site to keep working on this site and making it better. I will do so until someone from Chief Delphi pulls me away from it and tells me to stop. - Brandon Martus [more]
Unread 04-02-2008, 00:22
Amir's Avatar
Amir Amir is offline
FRC #1717 (dpengineering)
Amir is a splendid one to beholdAmir is a splendid one to beholdAmir is a splendid one to beholdAmir is a splendid one to beholdAmir is a splendid one to beholdAmir is a splendid one to beholdAmir is a splendid one to beholdAmir is a splendid one to behold
Re: pic: 1726 week 4
We have used the nylon spring-loaded ones from McMaster and it is kind of clunky and hard to incorporate into the chassis.
Can you tell me which nylon round stock you used? I don't need a picture but others may benefit from one.
Thanks
Amir
Unread 04-02-2008, 00:23
GUI GUI is offline
AKA: Gary
FRC #4183 (Bit Buckets)
GUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to behold
Send a message via Yahoo to GUI
I believe it was McMaster part # 8664K15
Unread 04-02-2008, 00:24
Matt H. Matt H. is offline
Long Distance Mentor
FRC #1726 (N.E.R.D.S.)
Matt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond repute
Do a mcmaster search for oil-filled nylon rods I believe we used either the 1 1/2in or the 2 in rod.
Unread 04-02-2008, 00:34
Amir's Avatar
Do you know if the oil-filled nylon is better than the oil-filled UHMWPE, part number 5243T23? The reason I ask is that the chain guides you are using are made from UHMWPE not nylon.
Unread 04-02-2008, 00:36
GUI GUI is offline
AKA: Gary
When playing with the chain, the UHMWPE seemed to be a little more slippery. We used the nylon because we already had it, if I was ordering material for the tensioners i would go for the UHMWPE.
Unread 04-02-2008, 00:25
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
McMaster part number 8664K15 is enough to last for a few years
Unread 04-02-2008, 00:32
Aren_Hill's Avatar
Build Nifty Things
i have to say i do like the pulltrusion shape that easily makes what would've taken multiple pieces of other materials to make. And it would've most likely ended up heavier.
looks like a great drive base, how much did you lower the center wheel?
A guy who likes robots.
GUI GUI is offline
AKA: Gary
Center wheel is lowered 1/8"
Unread 04-02-2008, 00:35
We used the nylon because we had it on hand--Either should work well.
pic: 1726 Promobot GUI Extra Discussion 18 01-11-2007 18:04
pic: 1726 NURC ROV s_forbes Extra Discussion 11 13-06-2007 23:54
pic: 1726 2007 OI TheOtherGuy Extra Discussion 2 11-02-2007 23:17
pic: 1726 Unfinished Parts MrForbes Extra Discussion 6 26-01-2007 00:14
pic: Real Pic of Team 1726 MegaMaid Progress yodameister Extra Discussion 4 12-02-2006 13:23
