#10
Re: Relay program?
the Setpwm (1, x) is a window that you put your variable in so "x" is set to the value of pwm 1
| Instance relay | Team_486 | Programming | 0 | 28-03-2007 09:56 |
| Relay Commands | Matt Krass | Programming | 6 | 18-02-2006 23:03 |
| Relay Assignments | MulletFish | Programming | 9 | 27-01-2005 14:15 |
| Relay fault | archiver | 2000 | 2 | 23-06-2002 23:36 |
| Relay Outputs | OddOne | Technical Discussion | 3 | 01-02-2002 19:52 |
