Go to Post This is far more then any little school extracurricular, this is a FIRST Robotics Team. - onecoolc [more]
Unread 31-01-2008, 16:53
Gizmo2417 Gizmo2417 is offline
Gizmo
FRC #2417 (Robocougars)
Gizmo2417 is an unknown quantity at this point
EasyC Pro Programming?
Hi I'm a member of FRC team 2417 and I am having a hard time figuring out how to program the robot with EasyC pro. We have a basic setup based on the electronics diagram, so which motors (1-16) would I use for the radio control, or am I totally on the wrong track?
Unread 31-01-2008, 16:59
Nathan's Avatar
Nathan Nathan is offline
FRC #1501 (Team T.H.R.U.S.T.)
Nathan has a spectacular aura aboutNathan has a spectacular aura aboutNathan has a spectacular aura about
Re: EasyC Pro Programming?
You have to find out what port the motors are plugged into. Like you said, it could be 1-16.
If you want the joystick values to be sent directly to the motors, expand the "RC Control" function block and drag in the appropriate function.
Nathan
Save money with PriceWombat, a shopping comparison and price tracking tool (that I made!).
Check out my hobby electronics business!
My former robotics team: Huntington County 4-H Robotics
Unread 31-01-2008, 22:50
DonRotolo's Avatar
Back to humble
FRC #0832
The cool part is that YOU determine that in software.
Open a new competition project.
Drag a While loop into Main, and set it "While (1)" - that'll make it run forever.
Inside the while loop, drag a "2 wheel tank" block in there, and define the PWM ports and joystick ports. (I think you define them there?)
Connect the motors (through vicotrs) to those ports, connect the joysticks, and see them work. 5 minutes of programming and downloading. Easy C.
Don
Unread 02-02-2008, 15:05
Gizmo
I put the tank2 in the While loop and it took off as soon as we turned it on. How do I get it to respond to the controller?
Unread 02-02-2008, 17:13
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
Some tips Gizmo to make your life easier:
1. Put your robot up on blocks (wheels off the ground) before turning it on for testing.
2. Get or make a competition port dongle. This lets you disable/enable the robot as well as switch between autonomous and operator control.
3. Use the tutorials in the EasyC help menu.
4. If you are using the kit joysticks, make sure you have the trims set properly. When you turn your robot on and your joysticks are in neutral, all of the Victors should be ORANGE. Adjust the joystick trims to make this so. If adjusting the trims does not work then you will have to calibrate your Victors.
Unread 04-02-2008, 00:54
Gizmo
How do you calibrate the victor? I read something about the joystick being pressed forward and back?
Unread 04-02-2008, 01:08
AKA: Dan
Check out the Victor884 manual. Make sure your joysticks are trimmed properly before doing the calibration, though.
http://www.ifirobotics.com/docs/ifi-...al-9-25-06.pdf
MS Vista/EasyC & EasyC Pro rswsmay Programming 1 25-04-2007 10:47
easyC Pro help! shlomi Programming 1 08-02-2007 06:48
EasyC Pro trial? Stuart Programming 3 07-02-2007 22:33
easyC PRO contest Brandon Martus Announcements 0 01-02-2007 11:57
