Re: Relay program?
So where in your program do you actually control the pwm output that you want to use as the trigger for your relay? |
Re: Relay program?
Normal operation would be to:
1) Get the desired drive value from the driver--GetOIAInput() 2) Do your tests on when you want your relay to be active--if () else 3) Output your relay command--SetRelay() 4) Set your PWM Output--SetPWM() |
| Instance relay | Team_486 | Programming | 0 | 28-03-2007 09:56 |
| Relay Commands | Matt Krass | Programming | 6 | 18-02-2006 23:03 |
| Relay Assignments | MulletFish | Programming | 9 | 27-01-2005 14:15 |
| Relay fault | archiver | 2000 | 2 | 23-06-2002 23:36 |
| Relay Outputs | OddOne | Technical Discussion | 3 | 01-02-2002 19:52 |
