Go to Post Getting that degree is the reason for going to college. Failing out of school because you mentored isn't really a good reason. - [more]
Unread 02-02-2008, 15:34
aeasson aeasson is offline
FRC #2435
aeasson is an unknown quantity at this point
SetDirection Function Call
Our team is using EasyC.
On page 33, the WPLIB manual states that for all controllers it is necessary to set the direction for any ports used for digital I/O – identifying each as either used for input or output.
However, I cannot find the SetDirection in the EasyC environment.
If it is not a built in function, then what are the possible values for direction in the function call.
Thank you
Unread 02-02-2008, 17:06
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
Re: SetDirection Function Call
Actually, EasyC has a GUI utility that makes setting the Digital I/O ports as easy as clicking the mouse. A picture of the RC comes up and you click on the I/O pins an the arrow toggles indication whether it is in or out. Check EasyC help on how to do it. Of course you can always make any WPILIB call with a user function call....
Unread 04-02-2008, 09:58
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Press "F5" on your keyboard.
Looping a function Tz0m Programming 14 20-02-2007 11:22
printf, call of function without prototype problems cprogrammer Programming 3 11-05-2006 18:21
"call of function without prototype" railerobotics Programming 7 21-01-2006 19:59
FreeLibrary() Function Raven_Writer Programming 0 09-08-2003 15:39
Programmers of FIRST, function call! archiver 2001 0 24-06-2002 03:58
