Go to Post Are yellow cards still being given out like AOL demo CDs in the late 90s? - Billfred [more]
Unread 02-04-2008, 09:59 AM
FIRSTMa2104's Avatar
FIRSTMa2104 FIRSTMa2104 is offline
FRC #2104 (Colonel Robotics)
FIRSTMa2104 is on a distinguished road
Not enought Serial ports
My team has decided to use a high-powered IR system but the receiver (which is suppose to be on the robot) use a serial port to connect to the RC and the RC has only 3 Serial port (including Tether). So is there any way to “create” a new serial port for the IR to connect to?
Unread 02-04-2008, 10:01 AM
Re: Not enought Serial ports
You can turn any of the digital I/O pins into serial connections by writing your own code.
Unread 02-04-2008, 10:02 AM
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
What are you using the existing serial ports for?
HTH
Unread 02-04-2008, 11:16 AM
ohh, ok will do that. thx
HTH
We will need the tether for practice in competitions, radio for the radio, program for downloading code into RC.
Unread 02-04-2008, 11:19 AM
The FRC has two serial ports--the program port and the TTL port (small pins on the side).
The tether is not a standard serial port that you can use and neither is the radio port.
For your purpose look at using the TTL port. It'll do what you need.
Unread 02-04-2008, 11:38 AM
thx great help at the moment we are looking at TTL to RS 232 converters.
great help see you in UTC i see you are going to be there.
Unread 02-04-2008, 11:45 AM
Originally Posted by FIRSTMa2104 View Post
thx great help at the moment we are looking at TTL to RC 232 converters.
IFI makes one "TTL to RS-232 Converter Board" for $10. http://ifirobotics.com/camera.shtml
Unread 02-04-2008, 12:22 PM
Mike Hendricks Mike Hendricks is offline
misses his IFI control system
FRC #0973 (GRR)
Mike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to all
You can use the program port for this, just unplug your IR board when you need to load your program .. this was a common practice for those who used the feedback on the old IFI breaker panels.
2004-2010: Founding Member, Technical Mentor - Team 1388, Eagle Robotics
2011: ???
Unread 02-04-2008, 02:15 PM
I told my mentor but I think he already ordered a TTL to RS-232.
Unread 02-05-2008, 02:51 AM
garyk garyk is offline
Programming Mentor: 668, 972, 2643
FRC #0668 (Apes of Wrath)
garyk is a jewel in the roughgaryk is a jewel in the roughgaryk is a jewel in the roughgaryk is a jewel in the rough
A TTL - RS232 converter was standard in the KOP for years 2005, 2006, and 2007. It's the postage-stamp sized PC board connecting the CMU camera to the RC's "TTL Serial Port", the four pins between the Relay Outputs and the Reset button. You can get an idea how to read the serial port from the camera code of years past.
Unread 02-05-2008, 11:40 AM
Los Frijoles's Avatar
Los Frijoles Los Frijoles is offline
Stormin' Mormon
AKA: Kevin Cuzner
FRC #2062 (C.O.R.E.)
Los Frijoles has a spectacular aura aboutLos Frijoles has a spectacular aura about
Send a message via AIM to Los Frijoles
You could always program your own UART code and use a MAX232 chip...however that requires considerable programming experience.
Community Of Robotic Engineers 2062
Blender totally pwns 3DS Max...
My life is here and here.
Cuznersoft Hardware and Software Development
Serial ports teh_pwnerer795 Programming 2 12-27-2006 12:47 AM
Serial ports Cuog Programming 3 05-02-2006 12:32 PM
Serial Driver and 2K6 Encoder Driver Not compatible Tom Bottiglieri Programming 6 02-12-2006 01:11 AM
Accessing serial ports koenig3456 Programming 1 02-02-2006 07:57 AM
Where can we get PS2 type game controllers with serial ports? waialua359 Control System 12 01-25-2006 10:33 PM
