Go to Post Dave: THEY'RE NOT DOLLIES THEY'RE MY FRIENDS! - Dorienne [more]
Unread 04-02-2008, 11:11
Re: Relay program?
Normal operation would be to:
1) Get the desired drive value from the driver--GetOIAInput()
2) Do your tests on when you want your relay to be active--if () else
3) Output your relay command--SetRelay()
4) Set your PWM Output--SetPWM()
Instance relay Team_486 Programming 0 28-03-2007 09:56
Relay Commands Matt Krass Programming 6 18-02-2006 23:03
Relay Assignments MulletFish Programming 9 27-01-2005 14:15
Relay fault archiver 2000 2 23-06-2002 23:36
Relay Outputs OddOne Technical Discussion 3 01-02-2002 19:52
