Go to Post Uhh... we were supposed to be building a robot? *looks at giant wooden Trojan Rabbit in the corner that was built instead for the past 6 weeks* Whoops... - Adam Richards [more]
Unread 01-02-2008, 19:40
Padre_Vez's Avatar
Padre_Vez Padre_Vez is offline
National Inventor Award Winner 2007
AKA: Jonathan
FRC #0103 (Cybersonics)
Padre_Vez is on a distinguished road
Spoiler Alert Team 103
This is our wheel for the year we wanted to know what you guys thought of it? We were also wondering if anyone knew how to get rid of the weird things around the tread? We couldn’t figure it out so it would be a big help if anyone could figure it out.
Unread 01-02-2008, 19:42
SSMike's Avatar
SSMike SSMike is offline
The Guy with the Big Blue Two
FRC #0250 (The Dynamos)
Team Role: Operator
SSMike has a reputation beyond reputeSSMike has a reputation beyond reputeSSMike has a reputation beyond reputeSSMike has a reputation beyond reputeSSMike has a reputation beyond reputeSSMike has a reputation beyond reputeSSMike has a reputation beyond reputeSSMike has a reputation beyond reputeSSMike has a reputation beyond reputeSSMike has a reputation beyond reputeSSMike has a reputation beyond repute
Re: Spoiler Alert Team 103
Looks really good. As to the things on the treads, if we knew what program you used I'm sure someone could help you. <-- If its Inventor, I would recommend using a workplane and cutting the "things" off. Other than, the wheel looks really good.
Long Live #4
Just when I find the key to success, someone goes and changes all the locks.
"It's kind of fun to do the impossible" -Walt Disney
When you put 'THE' and 'IRS' together, it forms 'THEIRS'. Coincidence? I think not!
Why is the name of the phobia for the fear of long words: hippopotomonstrosesquippedaliophobia?
"There's no such thing as a winnable war......." Bring our Troops Home
I will never let you fall
I'll stand up with you forever
I'll be there for you through it all
Even if saving you sends me to heaven
--The Red Jumpsuit Apparatus
Unread 01-02-2008, 19:50
Padre_Vez's Avatar
AKA: Jonathan
It is Inventor but the "things" appear randomly and never in the same place so we're utterly confused.
Unread 01-02-2008, 19:59
Padre_Vez's Avatar
AKA: Jonathan
This is just a close up view of the problem.
Beyond the reach of human range
A drop of hell, a touch of strange
Unread 01-02-2008, 20:26
REVving up for a new season
FRC #2848 (All-sparks)
it appears to me that it is on every 5th row. I would first check the part that you are patterning to see if that feature exists, if it does check that there. a quick way to get rid of it might be to do a cut at the right diameter out which should remove the anomaly.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 02-02-2008, 05:15
Waynep Waynep is offline
217 Alum, Former 395/348 Mentor
FRC #1923 (MidKnight Inventors)
Waynep has a reputation beyond reputeWaynep has a reputation beyond reputeWaynep has a reputation beyond reputeWaynep has a reputation beyond reputeWaynep has a reputation beyond reputeWaynep has a reputation beyond reputeWaynep has a reputation beyond reputeWaynep has a reputation beyond reputeWaynep has a reputation beyond reputeWaynep has a reputation beyond reputeWaynep has a reputation beyond repute
Great job modeling the wheels. What I also find interesting is that very large gear behind it. I'm curious whether or not you guys are taking a play off of your running buddies from NJ and running an all gear tranny. Hmmm 25 drivetrain with what I believe to be AM Performance Wheels....gorgeous and deadly combo.
395 2TrainRobotics
Regional Champs- '03 VA, '05 PIT, '05 NY, '06 PIT, '06 NY; Regional Finalist- '04 NY; Engineering Inspiration- '03 NY, '06 PIT; Regional Chairman's Award- '04 NY
348 Norwell Robotics
2008 NY Regional Finalist; 2008 Curie Division Champs; 2008 World Championship Finalists
1923 MidKnight Inventors
2009 NJ Regional Champs; 2010 BOS Engineering Inspiration Award; 2011 CT Regional Champs, Gracious Professionalism Award, Coopertition Award
Unread 02-02-2008, 09:38
JD Mather's Avatar
JD Mather JD Mather is offline
JD Mather is a jewel in the roughJD Mather is a jewel in the roughJD Mather is a jewel in the roughJD Mather is a jewel in the rough
Originally Posted by Padre_Vez View Post
... wondering if anyone knew how to get rid of the weird things around the tread?
Can you post the file?
Autodesk Inventor Certified Expert
Certified SolidWorks Professional
AU 2007 Avatech Altogether Smarter Inventor Challenge 1st Place
http://home.pct.edu/~jmather/content..._tutorials.htm
Unread 02-02-2008, 10:03
Padre_Vez's Avatar
AKA: Jonathan
How do we post the file up on this website and is their any other way i can send it to you.
Unread 02-02-2008, 10:16
Logan's Avatar
Logan Logan is offline
Inventor Zombie
Logan is on a distinguished road
Its important to know that when you rotate the assembly and play around zooming in it goes away, but if you zoom out it always comes back. Also when you click a couple times on the cone feature it sometimes goes away.
[edit]
Forgot one thing, in responce to mike, It was in inventor and the cones aren't actually there. We tried cutting them off however it didn't work.
Unread 03-02-2008, 19:19
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
I did this once and crashed several computers because I used several patterns. They save a lot of time but sometimes give trouble with the computer. It tends to get confused if you do it too many times with too much details. I would request that you post a list of commands you used in the order that you used them. I know it sounds weird, but a lot of troubles can be figured out this way.
"Curiosity. Not good for cats, great for scientists."- Numb3rs
"They can break your cookie, but... you'll always have your fortune."-T.W. Turtle, Cats Don't Dance
"Tell my tale to those who ask. Tell it truly - the ill deeds along with the good, and let me be judged accordingly. The rest... is silence."-Dinobot, Beast Wars
"Though the first step is the hardest and the last step ends the quest, the long steps in between are certainly the best."
–Gruffi Gummi, Disney's Adventures of the Gummi Bears
Unread 04-02-2008, 11:15
grsnovi's Avatar
grsnovi grsnovi is offline
Autodesk Inventor Team - Portland,
AKA: Gary R Smith
FRC #2542
grsnovi will become famous soon enough
The "things" that appear at random around the tread are probably graphical anomalies that may have to do with sketch integrity. Can we assume that your wheel is an assembly or did you model all of the parts as features within a single part? As JD suggests, if you can post the tread part here, somebody could look at it. It would be good if prior to posting you rolled your end of part marker all the way up to the top and then post a zip file of that.
Unread 04-02-2008, 16:03
Logan's Avatar
Inventor Zombie
I think this pretty much sums it up. the pictures take a second to load.
Unread 07-02-2008, 13:53
Dancin103 Dancin103 is offline
The Crazy Blonde
AKA: Cassie
Dancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond repute
Send a message via AIM to Dancin103
Guys you are awesome, i am looking at this in study hall and this is just sick! keep up the great work!
Cybersonics Technology Team 103
2003 Championship Chairman's Award Winners
NEED CHAIRMAN'S HELP?? Subscribe to our YouTube Channel, we answer your questions daily!
Unread 07-02-2008, 19:17
Molten's Avatar
AKA: Jason
I may be way off on this, but at first glance I can only see 1 real mistake you made. It seems that you did not go in and trim the geometry in your first sketch. If I were you, I would make sure to save the file (what I am about to tell you to try might mess up the part or it might fix it). Then, go in and trim the geometry so it is just 1 shape(just make sure you don't have lines overlapping). Finally, finish sketch and let the computer process. Is the part the same? Did it fix? If not, please post another picture if it looks any different.
Disclaimer: If something goes wrong, you should be able to undo anything I stated above. However, what I said above is just something that I have noticed over the years to sometimes work. It is not a guarantee.
Unread 07-02-2008, 20:40
DonRotolo's Avatar
Back to humble
FRC #0832
In the sketch I see 5 "teeth" then a half (maybe a 1/4) tooth at the bottom - what's that doing there? Seems like that's your anomaly.
Don
pic: Team 56 Positioning a Spoiler jfischer Robot Showcase 13 21-02-2007 23:42
Team 103 Robot Robert Thacker- Inventor 36 08-05-2006 15:08
Team in a Box V. 2 : Featuring Team 67 and Team 103 OZ_341 General Forum 7 30-01-2006 16:53
Thanks Team 103 Anne George Thanks and/or Congrats 5 26-07-2003 21:56
Congratulations team #103 and team #175 archiver 2000 2 23-06-2002 23:02
