Go to Post I emailed Brandon Martus to have my username changed. It was updated within a day. Champion webmaster at work. - Gregor [more]
Unread 03-02-2008, 21:37
MCahoon MCahoon is offline
FRC #3826 (Sequim Robotics Federation)
MCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud of
Re: Best way to remove fisher price pinion???
Originally Posted by Josh Murphy View Post
We use a pin that is slightly smaller than the shaft and then use an arbour press to take it off. It works real well for us, I just did some fisher price motors the other day and had no problems.
How do you hold the pinion gear when pressing the gear off?
Unread 03-02-2008, 21:41
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
I used a hammer and cold chisel, split the gear in half lengthwise, very quick and easy. Support the gear on a big chunk of solid metal like the anvil part of a bench vice or a heavy welding table, put the chisel in the space between the two topmost teeth, and give it a good whack with a big hammer.
Needless to say the gear will not be useable after this operation.
Unread 03-02-2008, 21:42
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
See my previous post in this thread with the picture of the plate. Best way we've found to hold it.
2001-2004: Team 100
2006-Present: Team 254
Unread 03-02-2008, 22:19
Jimmy Cao Jimmy Cao is offline
AKA: Jimmy Cao
Jimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant future
OHHH I just did this yesterday for the first time xD
So... We made a plate that fit on the shaft under the pinion. We cut that little plastic spacer off. A 1/8" Steel plate w/ a slot went right in.
We put another plate in, and used a shop press to press the motor off the pinion.
Jimmy Cao
Team 469 2006-2010 Student/Alumni
Team 830 2011-2012 Mentor
Unread 03-02-2008, 22:24
Josh Murphy's Avatar
Josh Murphy Josh Murphy is offline
AKA: Josh
FRC #0051 (Wings of Fire)
Josh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond repute
We have a fixture that we use. I can post a picture of it tomorrow.
-Josh Murphy-
Unread 03-02-2008, 22:37
Mike Hendricks Mike Hendricks is offline
misses his IFI control system
FRC #0973 (GRR)
Mike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to all
We did the same (with the plate). It was a 1/8" steel plate with a slot cut in it for the motor to slide into. Then we used a hardened nail (don't ask, I have no clue where it came from) and ground it down until it was small enough to touch only the shaft. Then we used an arbor press to press the pinion off.
With that being said, I will join the others who used a nutsplitter - they're wonderful.
2004-2010: Founding Member, Technical Mentor - Team 1388, Eagle Robotics
2011: ???
Unread 03-02-2008, 23:32
Cory: I very much appreciated your response in your previous post. It saved me the time that would have been lost in ordering the Banebots puller to find it didn't work (I had it in my cart on their site). I suspect the longer pinion gear is just too much for the hobby puller to handle. We have an arbor press, and your aluminum fixture would be a great solution, but we have to borrow machine shop time and it would likely take a couple of days to get built. The slotted steel plate looks like a workable situation that could be made with basic hand tools, though it doesn't provide as secure a hold on the pinion. Maybe after build season?
Squirrel: Your solution as well as the nut breaker would work. We'll need to do the same thing with an RS550 motor and plan to reuse that pinion, so need to have a way to remove them without destroying them. By nature I am a pack-rat and it seems like somewhere/sometime we'll have a need for a 19 tooth gear (I have boxes of this kind of stuff), so I'll advise not destroyinng it.
Thanks to all for the flurry of responses. I'll offer these as suggestions to the team and let them decide how they want to do it.
Martin
Unread 04-02-2008, 11:35
AKA: Josh
Here are the pictures of what we use to take the fisher price pinions off with. We made this out of aluminum.
ID:	6205  Click image for larger version
ID:	6206  Click image for larger version
-Josh Murphy-
Unread 04-02-2008, 11:43
MrForbes's Avatar
AKA: Jim
That's a very nice gear puller!
Unread 04-02-2008, 11:45
Richard McClellan's Avatar
Richard McClellan Richard McClellan is offline
Engineering Mentor
FRC #0254 (Cheesy Poofs)
Richard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud of
Send a message via AIM to Richard McClellan
Very nice! What's the thickness of the part that goes under the actual pinion? And I assume you guys have an arbor press as well? Or would a drill press work with this tool?
~ Richard McClellan ~
Former Student on 1477 | Northside Roboteers | 2004-2005
Former Lead Mentor for 2158 | ausTIN CANs | 2007-2010
Current Mentor for 254 | Cheesy Poofs | 2013
Unread 04-02-2008, 12:38
AKA: Josh
We do use an arbor press. A drill press is not a very good option unless it's last resort. The actual part that goes under the pinion is made of steel(unlike what I said earlier) and the rest is made of aluminum(like I said earlier). The actual thickness that goes under the pinion is 0.085". This works really well for us.
-Josh Murphy-
Fisher-Price 00968-9012 motor pinion Joe P Motors 3 03-04-2007 19:31
fisher-price pinion gear bill mc gowan Motors 6 06-03-2006 11:14
Fisher Price Pinion Pressure Angle alphastryk Motors 1 04-02-2006 21:06
Fisher Price Gearboxes Nathan Pell Motors 7 06-03-2004 11:29
Legal way to remove bottles? and other questions jrukes Off-Season Events 4 15-10-2001 22:35
