Go to Post I'm always afraid of what the GDC will come up with... Their sanity is often questioned... :D - thefro526 [more]
Unread 03-02-2008, 16:22
neoshaakti's Avatar
neoshaakti neoshaakti is offline
FRC #2554 (WarHawks)
neoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to behold
Send a message via AIM to neoshaakti
Bumper help
I have cut 3/8'' plywood down to size, but I have recently found out that our bumpers have to be 3/4" plywood
do you recommend me either gluing or nailing two 3/8'' pieces together to form a 3/4" piece?
also, are you guys just using hex bolts to attach your bumpers to your chassis?
Unread 03-02-2008, 16:25
Re: Bumper help
You are not allowed to make your own plywood/laminate, according to Q&A. Sorry.
Unread 03-02-2008, 16:27
Steve_Alaniz Steve_Alaniz is offline
FRC #2848 (All Sparks)
Steve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond repute
Re: Bumper help
The bumpers, especially in this game, are going to take a LOT of punishment... You'd have to cut additional 3/8 pieces anyway so I'd suggest you just start over with 3/4. You wouldn't want them breaking apart during competition. That might disqualify your team. After all that work it wouldn't be worth the risk.
I you just HAVE to use 3/8"... glue AND nail them.
My 2 cents
Steve
Unread 03-02-2008, 16:48
dscreen11's Avatar
dscreen11 dscreen11 is offline
FRC #1594
dscreen11 is an unknown quantity at this point
Re: Bumper help
Yeah, you'll have to start over again with a new piece of plywood. I know that is probably fustrating
Unread 03-02-2008, 16:52
ALIBI's Avatar
ALIBI ALIBI is offline
FRC #0141
Team Role: Parent
ALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to all
Re: Bumper help
If you can, try and find something with at least seven plies. Three and five ply are not as strong. We usually try and use 3/4 T & G flooring plywood.
Unread 04-02-2008, 02:51
Richard McClellan's Avatar
Richard McClellan Richard McClellan is offline
Engineering Mentor
FRC #0254 (Cheesy Poofs)
Richard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud of
Send a message via AIM to Richard McClellan
Re: Bumper help
We used hex bolts to attach our bumpers last year going straight into the KOP frame and it was a real pain. Whenever we had to remove the bumpers for inspection or working on the robot, and put them back on, it was not fun fiddling with nuts inside the chassis channel.
This year, we're attached L-brackets to the bumpers and have bolts that go vertically through the top and bottom of the KOP chassis channel and tighten down with wingnuts, and so far it has been so much easier to work on. I would recommend putting the effort in to make bumpers that are easy to remove and reattach.
~ Richard McClellan ~
Former Student on 1477 | Northside Roboteers | 2004-2005
Former Lead Mentor for 2158 | ausTIN CANs | 2007-2010
Current Mentor for 254 | Cheesy Poofs | 2013
Unread 04-02-2008, 07:25
GaryVoshol's Avatar
Cogito ergo arbitro
Re: Bumper help
Originally Posted by richardmcc2 View Post
This year, we're attached L-brackets to the bumpers ...
Brackets attached to the bumpers themselves are a non-standard construction and not allowed. You may have brackets attached to your frame, which are then used as the attachment point for a bolt that comes from the bumper. This is my opinion, and not official - please review <R08> and the various Q&A's regarding bumpers.
(since 2004)
Unread 04-02-2008, 12:01
Browzilla Browzilla is offline
Fearless Leader
AKA: David Vriezen
FRC #2530 (Team Inconceivable)
Team Role: Electrical
Browzilla is on a distinguished road
Send a message via AIM to Browzilla Send a message via MSN to Browzilla
Re: Bumper help
There's a post in the Q&A regarding this. Mounting brackets are fine, but aren't part of the bumper, so they must meet the robot's size and weight standards.
http://forums.usfirst.org/showthread...t=bumper+mount
Unread 05-02-2008, 16:24
insanehippoz's Avatar
insanehippoz insanehippoz is offline
AKA: Kelsie
FRC #1038 (Thunderhawks)
insanehippoz is an unknown quantity at this point
Re: Bumper help
Are we allowed to reuse bummers?
The bummers from last year are the same dimensions that we need for this years robot so it would save a lot of time, money and energy to just reuse them.
Unread 05-02-2008, 16:26
Re: Bumper help
Already been asked in the Q&A. The response was something to the effect of "bumpers are a fabricated item and therefore may not be salvaged from old robots."
Unread 05-02-2008, 16:29
AKA: Kelsie
Re: Bumper help
ohh ok, we weren't sure because they aren't included in the robot dimensions or initial weight. Thank you
Unread 05-02-2008, 16:43
neoshaakti's Avatar
Re: Bumper help
do u think trying to glue down the hex bolt to the plywood (or inside the plywood) is a good idea?
L brackets are a pain b/c they have to fit within the dimensions...and I doubt I have 1,5'' on the length and width to use
Unread 05-02-2008, 17:09
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Re: Bumper help
Things like Blind Nuts work great for attaching bumpers.
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXK019
The little tangs you see sticking up get pressed (re: Hammered) into the wood, and hold very well.
These require access to whatever you are mounting the bumper to from the other side, so because of this aspect, it may not work for everyone.
Bumper Qs Woody1458 General Forum 13 29-01-2009 16:41
need help w/ bumper fastner designs lopz056 General Forum 6 06-02-2008 09:54
bumper coolguybigt Technical Discussion 4 27-02-2007 16:40
Bumper or No? WebWader125 Technical Discussion 19 11-01-2006 01:28
Bumper sensors jeffmorris FIRST Tech Challenge 1 02-10-2005 16:20
