Go to Post Remember, if FIRST is your top priority, you need to look at your priorities. - Billfred [more]
Unread 03-02-2008, 15:46
bhsrobotics1671's Avatar
bhsrobotics1671 bhsrobotics1671 is offline
Andrew Nabors
AKA: Andrew Nabors
FRC #1671 (Buchanan Bird Brains)
bhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to behold
Question 2 FESTO valves on 1 spike
does anyone know if its legal or even possible (without the fuse tripping) to connect to FESTO valves to one spike. they are each out puting to one cylindar, on our arm the is a mirror image on both sides.
we are just trying to reduce the amount of spikes that we are using and are wondering if FIRST, or our current, will allow it.
thanks!
Buchanan Bird Brains - FRC Team 1671
2015 FIRST World Champions
118, 1678, 1671, 5012
Unread 03-02-2008, 15:52
seanl's Avatar
seanl seanl is offline
"The Everything person"
FRC #0867 (Absolute Value)
seanl will become famous soon enoughseanl will become famous soon enough
Re: 2 FESTO valves on 1 spike
why dont you just put a T on the pneumatic tubing and run it to the two cylinders thats what we did. and less weight from the extra festo.
, Sean
TEAM 867
-electrical
-pneumatics
-programming
2008 Autodesk Visualization Grand Prize Winner
Unread 03-02-2008, 15:54
Chaos204's Avatar
Chaos204 Chaos204 is offline
AKA: Jordan
FRC #0204 (Eastern Robotic Vikings)
Chaos204 is on a distinguished road
Send a message via AIM to Chaos204
is there a reason that you are not putting a T splitter on one festo? I don't have much experience with festos specifically but the regular valves work with one valve with a T split
2005 PARC FINALIST
with 84 and 176
E. R. V. is on its way
Unread 03-02-2008, 16:08
adamm adamm is offline
AKA: Michael Adam
FRC #1671 (The Bird Brains)
adamm is just really niceadamm is just really niceadamm is just really niceadamm is just really niceadamm is just really nice
I'm also on team #1671.
We are using 2 values becuase we need fast airflow. From what I've been told 2 festo valules will allow faster airflow than 1 with a T. Also, with the T adapter, one piston could take more of the airflow if the other has more resistance on it. We need them to move equally at the same time.
We are mainly curious as to how much draw the values have when in use.
I will try to see if the T is a valid option on our robot.
Michael Adam
Director, Central Valley Robotics
FLL and FLL Jr. Affiliate Partner, Central California (2009-Present)
Member, Central Valley Regional Planning Committee (2012-Present)
Volunteer of the Year, Central Valley Regional (2015)
FRC Control System Advisor (2013-Present)
FRC Scorekeeper (2015-Present)
Mentor, Team 1671 (2009-Present)
Member, Team 1671 (2005-2009)
Unread 03-02-2008, 16:11
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
The Festo valves have very low current draw compared to what a Spike can supply, so you need not be concerned about it for that reason. Just make sure to carefully read the rules and see if it is allowed! also I would think that having both cylinders connected to the same tube with a T would be the best way to balance the air pressure between them. However, that won't guarantee that they will move at the same rate.
Unread 03-02-2008, 17:29
Brad Voracek Brad Voracek is offline
.999~=1
FRC #0399 (Eagle Robotics)
Brad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of light
Send a message via AIM to Brad Voracek
We are planning on running 2 spikes (y-cable'd together) to 2 valves, then have a system to make sure they run around the same, but still with the increased airflow.
Our system looks something like this:
http://img266.imageshack.us/img266/601/flowms7.jpg
... we ran a spike on each for some reason I don't know. Probably because our team thought it was illegal to run 2 off of one. ;P
.999~ (Repeating) is equal to one (1).
Team 399 - Eagle Robotics
Unread 04-02-2008, 07:54
Andrew,
This is the rule that addresses your question.
<R56> Each power regulating device (Victor speed controller or Spike relay) shall control one and
only one electrical load (motor, actuator or compressor). Multiple low-load devices (e.g.
pneumatic valves) may be connected to relay modules (but only one motor may be
connected to each relay module).
Unread 04-02-2008, 08:26
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
It is possible to connect two single solenoids to a single Spike, and control them independently. See here for the wiring diagram: http://www.ifirobotics.com/docs/spik...uide-sep05.pdf on page 2.
Please note that this has been a legal setup in the past, but rules from prior years do not apply to this year. I can't comment on the legality at this time, and your best bet will be to ask the official Q&A.
FYI, using the referenced setup above, you'll quickly discover that you can actually run a Spike relay in both forward and reverse at the same time. This brings both output pins high to 12V, which would activate both solenoids simultaneously.
Unread 04-02-2008, 12:14
HUNT397's Avatar
HUNT397 HUNT397 is offline
AKA: Chris Hunt
FRC #0397 (Knight Riders)
HUNT397 is a splendid one to beholdHUNT397 is a splendid one to beholdHUNT397 is a splendid one to beholdHUNT397 is a splendid one to beholdHUNT397 is a splendid one to beholdHUNT397 is a splendid one to beholdHUNT397 is a splendid one to behold
If we take four festo's and put them in parell with one another using a terminal and fire them with one spike would that be legal? If it is described in (r56) can someone please clairify.
Unread 04-02-2008, 12:45
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
While the combined flow rate of 2 Festo valves is more than 1:
Norgen regulators have a 14 SCFM flow rate.
Festo valves have a 14 SCFM dlow rate.
Thus, unless you put some of the clippard volume chambers downstream of the regulator, running 2 Festo valves will produce a slower cylinder response than just 1 Festo valve (I know ... we tried it).
Also "T"s add restriction by creating non-laminar flow, which will reduce the flow in the system.
___________________
- Tennyson, Ulysses
Unread 04-02-2008, 16:23
GBIT's Avatar
GBIT GBIT is offline
Lexantologist/Team Lead
AKA: Jared
FRC #0811 (Cardinals)
GBIT is just really niceGBIT is just really niceGBIT is just really niceGBIT is just really niceGBIT is just really nice
Send a message via AIM to GBIT
your actually better off using one solenoid and putting a "Y" joing in line to the two cylinders. It keeps the system more linear. and if you are really looking for a lot of air flow try the FESTO tiger valves. They used to be supplied in the kit so they are legal. The festo valve moves about 300 liters a minute i believe and the tiger valve moves about 1100 i believe i was told.
but depending on your bore size it should move fast enough to do what ever you want it to with just one of the new festo valves.
-Mentor-
-WPI '13-
-Former Team Lead-
-Past Driver-
Unread 08-02-2008, 12:19
HUNT397's Avatar
AKA: Chris Hunt
Back to the origional question. Can multiple festo valves be ran off of one spike? Rule 56 appears to say yes. What do you think?
Unread 08-02-2008, 13:37
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
This is addressed directly by the rule you have quoted as well as the Q&A in multiple responses. Multiple valves may be run off of the same spike.
Leaky Valves Mark Deutsch Pneumatics 9 16-02-2007 15:07
Festo itay_ms Electrical 3 30-01-2007 09:08
solenoid valves? brian1717 Pneumatics 2 07-01-2007 15:28
small pneumatic valves technic master Technical Discussion 8 07-10-2004 19:18
Leak of FIRST Valves Andy Baker Rumor Mill 0 12-10-2001 23:20
