Go to Post I don't actually have any hex shaft stock in my house (I live in an unusual household). - ollien [more]
Unread 04-02-2008, 13:35
MaddyW MaddyW is offline
FRC #0486
MaddyW is an unknown quantity at this point
Additional IR Sensors?
The robot will be unable to receive IR input after the robot has turned around the track because the sensor will be facing the oppostie direction. Have any teams considered having multiple IR receivers and then retransmitting back to the original sensor?
Is there a rule preventing repeating of IR codes for fear of interfering with other robots?
If not, is there a rule about having multiple IR receivers or altering the supplied receiver?
Unread 04-02-2008, 14:03
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: Additional IR Sensors?
There is no rule that would prohibit what you describe.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 04-02-2008, 14:24
Spencer E.'s Avatar
Spencer E. Spencer E. is offline
Android junkie
FRC #1305 (NNSRI Ice3 (cubed))
Spencer E. has a spectacular aura aboutSpencer E. has a spectacular aura about
Send a message via MSN to Spencer E.
The IR sensors actually has a 360 degree field of view. Our team tried it out (with a BetaMax remote :O) and we noticed that it could recieve a signal from any angle (if not obstructed of course). As long as you don't have anything to limit its FOV you should be fine.
Additional Processors chris31 Programming 12 22-09-2006 23:07
where can we buy hall effect sensors or gear tooth sensors amirjpl Electrical 3 13-02-2006 11:02
Source for Additional Gear Tooth Sensors Madison Kit & Additional Hardware 3 18-01-2006 16:57
Additional Parts ph@ntom Robotics Education and Curriculum 6 23-11-2004 23:52
additional materials Penn Robotics Off-Season Events 1 01-11-2001 23:25
