Go to Post Take care of what's there and you never need a replacement. - Rich Kressly [more]
Unread 04-02-2008, 13:28
EFastring EFastring is offline
AKA: Eric Fastring
FRC #2078 (Robotic Wolves)
EFastring is an unknown quantity at this point
Testing the Kit Gyro?
What is the easiest way to test the kit gyro to see if it is working?
I tried hooking up a PWM cable to analog input 1, and connecting it to the gyro (white to TW, black to GB, red to 5R) and adding a printf line to user_routines.c to display rc_ana_in01.
I get a constant output of 135 regardless of if I twist the gyro or even have it plugged in.
Does the gyro need to be initialized, calibrated, etc. before it will function at all, is my printf referencing the wrong variable, or am I doing something else wrong to see if the gyro is simply functioning at all?
Unread 04-02-2008, 13:37
Re: Testing the Kit Gyro?
rc_ana_in01 is a constant. You have to use Get_Analog_Value( rc_ana_in01 ) in order to get the actual analog value.
Unread 04-02-2008, 14:01
AKA: Eric Fastring
Ah, excellent. Thanks for the quick reply. I will give it a shot.
Unread 04-02-2008, 14:05
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Also, constant values from the gyro are a common sign that you've wired it incorrectly. Ensure that your wires connects to the pins labeled with a T, not the ones with an R.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 04-02-2008, 16:08
Mike Hendricks Mike Hendricks is offline
misses his IFI control system
FRC #0973 (GRR)
Mike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to all
Unless of course you wish to read relative temperature off the sensor. We figured this out the hard way last year ..
2004-2010: Founding Member, Technical Mentor - Team 1388, Eagle Robotics
2011: ???
pic: Testing the Lift Rapt0r9 Extra Discussion 2 04-02-2008 17:10
pic: 418: testing controller on the roboticWanderor Extra Discussion 1 14-01-2008 23:45
How do i connect the camera for testing? naor52 Programming 1 12-01-2006 01:11
pic: Testing the arm... Rob Robot Showcase 15 11-02-2005 20:34
