Go to Post Picking up tetra's is going to be as easy as picking up a person of the opposite sex. While a select few will master it; others will be bumbling maroons.. - Elgin Clock [more]
Unread 31-01-2008, 22:03
JoshD's Avatar
JoshD JoshD is offline
FRC #0975 (Synergy)
JoshD is a splendid one to beholdJoshD is a splendid one to beholdJoshD is a splendid one to beholdJoshD is a splendid one to beholdJoshD is a splendid one to beholdJoshD is a splendid one to beholdJoshD is a splendid one to behold
Send a message via AIM to JoshD Send a message via MSN to JoshD
Talking 975's Working Arm
Well our first 3 1/2 weeks have been busy. This, as of tonight is our design. There are still kinks to work out, and there is still discussion on if we should can the hurdling idea. Anyway enjoy!
P.S. sorry about the weird turn towards the end, it was filmed with a digital camera and I didn't realize it would view sideways.
Click!!
Unread 31-01-2008, 22:06
DarkFlame145 DarkFlame145 is offline
That guy
AKA: Dennis
no team (None this season)
DarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud of
Send a message via AIM to DarkFlame145
Re: 975's Working Arm
very nice, seams to work very well.
TR-X 145 of Norwich, NY: Student 2005-2008
Exploding Bacon 1902 of Winter Park, FL: Mentor 2009
US Navy Corpsman 2011-????
Unread 31-01-2008, 23:09
GaryVoshol's Avatar
Cogito ergo arbitro
How far forward does that arm go? It looks like you're way outside the 80" limit.
(since 2004)
Unread 01-02-2008, 00:23
Dunno, Gary. Looks like it's about 4 ft. long (guesstimate based on robot height). That's 48", some of which is over the robot. They're close, but I'm not sure they are over yet. If it is over 80"...Then their mentor is right about it not working.
Unread 01-02-2008, 07:57
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Interesting gripper design.
I can't really tell... is this thing rotating to the up position under it's own power? It seems like someone was always holding on to it.
If it is powered, does it spin with enough force and speed to hurdle the ball?
It also sounds like there's a motor that was running a lot in the back ground, and it seemed to be loosely coincident with the gripper opening and closing. Is your gripper electromechanical?
Cool.
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 01-02-2008, 08:00
GaryVoshol's Avatar
Cogito ergo arbitro
Yeah, we don't have a good angle to see it. It just seems to be way in front of the bot as its moving up in the arc. Another factor is the width of the grabber around the ball, which could add a few inches to the maximum size. I was just issuing a friendly warning, in case they had forgotten to consider it.
I also presume that after they get the rest of the guts put in, they won't have to have 2-3 people around the bot to balance it!
(since 2004)
Unread 01-02-2008, 08:21
JoshD's Avatar
FRC #0975 (Synergy)
Well it's on our nonmoving chassis so there is no weight under it. Also, it has two mechanisms, a motor to lift the arm, which it was doing under its on power, and a motor that powers a lead screw that moves the arms in and out. As for the 80" rule, I'm pretty sure were ok there, but we haven't check yet.
And yes, it does fit in the 28 by 38 starting configuration.
Unread 04-02-2008, 17:23
flyingcrayons's Avatar
flyingcrayons flyingcrayons is offline
Team 1089 Alum. RU Class of 2015.
FRC #1089 (Team Mercury)
flyingcrayons has much to be proud offlyingcrayons has much to be proud offlyingcrayons has much to be proud offlyingcrayons has much to be proud offlyingcrayons has much to be proud offlyingcrayons has much to be proud offlyingcrayons has much to be proud offlyingcrayons has much to be proud offlyingcrayons has much to be proud of
our team has something like that. thats all i can say. it looks good though.
Unread 04-02-2008, 17:35
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Do you have a Globe Motor set into a Banebots planetary gearbox? What gearbox are you using and at what ratio?
--Madison--
...down at the Ozdust!
Unread 04-02-2008, 17:48
JoshD's Avatar
FRC #0975 (Synergy)
I believe we are just running the lead screw striaght off the Banebots motor. We also moved the lead screw because in it's original position it kept binding.
pic: Team 975's Arm JoshD Extra Discussion 3 04-02-2008 17:27
Human Arm Arm Controller SgtMillhouse648 Control System 5 09-01-2008 00:03
424's 2007 robot arm is very similar to 340's 2004 robot arm. Ross340 Robot Showcase 7 19-11-2007 21:11
pic: Arm vs Arm CD47-Bot Extra Discussion 2 13-03-2003 12:37
GearBox Working Balbinot General Forum 2 08-01-2003 22:12
