Go to Post ...our football team was a state champion, but i don't see -them- going to atlanta and winning there! :D - Sam Lipscomb [more]
Unread 02-02-2008, 12:33
Pneumaticsman's Avatar
Pneumaticsman Pneumaticsman is offline
AKA: Mitch guzman
FRC #1566 (Ammoknights)
Pneumaticsman will become famous soon enoughPneumaticsman will become famous soon enough
Send a message via MSN to Pneumaticsman
Exclamation CRIMP SLEEVES
Is it wise to use #6 wire crimp sleeves to make the battery wires longer?
thanks
Unread 02-02-2008, 15:35
DevilsTech99's Avatar
DevilsTech99 DevilsTech99 is offline
Torched
AKA: Yatie
FRC #1559 (DevilTech)
Team Role: Electrical
DevilsTech99 is an unknown quantity at this point
Re: CRIMP SLEEVES
For my lots of expierience id say that its never wise to have a joint in the wire, but if you HAVE to then it shouldnt be a problem. An alternative is to make a power distributer that comes in the kit of parts and connect the wires that way
Me, I'm dishonest. And you can always trust a dishonest man to be dishonest. Honestly, its the honest ones you want to watch out for.
Optimism is over-rated; its better to face reality head-on
Unread 04-02-2008, 17:44
Re: CRIMP SLEEVES
Mitch,
It is not desirable to extend the battery cables. Adding #6 wire to the lengths already supplied add significant loss to your system. Since this is a critical component (all robot current flows through these wires and can be in excess of 400 amps several times during a match), I would recommend that if you need to extend the wire that you make up your own cables using parts available from Terminal Supply or one of the other suppliers. If you have questions, please contact me via PM and we can get a discussion going. It is far better to keep the #6 wires short and use #10 for individual branch circuits that need to be further away from the battery.
Unread 04-02-2008, 17:49
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Re: CRIMP SLEEVES
thanks
In my experience, if the battery connector wires must be extended, then your battery, switch, ground are probably too far away from each other or too inaccessible.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 04-02-2008, 18:51
ALIBI's Avatar
ALIBI ALIBI is offline
FRC #0141
Team Role: Parent
ALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to all
Re: CRIMP SLEEVES
The Anderson cable half that connects to the battery can not be extened. Since the weight is not counted in the robot weight, they do not want a couple extra pounds or more showing up via #6 wire. The Anderson cable half that feeds your electrical system could be extended, but I agree with Al S. that you should make your own cables.
Unread 14-02-2008, 17:00
Ziaholic's Avatar
Ziaholic Ziaholic is offline
Elec/SW Mentor
AKA: Marc
FRC #1164 (Project NEO)
Ziaholic is a jewel in the roughZiaholic is a jewel in the roughZiaholic is a jewel in the roughZiaholic is a jewel in the rough
Re: CRIMP SLEEVES
I was just reading this in the rules last night ... the rule stated that no more than 12" of cable can be on the battery. I don't have the rulebook handy at the moment, but Alibi is correct, it was related to the allowable weight.
There are 10 types of people. Those who understand binary, and those that do not.
Team #1164 - Project NEO Robotics
Sprockets and Crimp connectors archiver 2000 1 24-06-2002 00:26
What's up the Rambots' sleeves nowadays? archiver 2000 0 24-06-2002 00:01
