Go to Post [Goals For 2012] 1. Build on 20 years of hard work. 2. Inspire a new generation so they come back another year. 3. Repeat. - Koko Ed [more]
Unread 02-02-2008, 22:23
zkaratekid's Avatar
zkaratekid zkaratekid is offline
FRC #1138
Team Role: Human Player
zkaratekid will become famous soon enough
peltier coolers
can we use peltier coolers on our robots?
thanks
2009 Los Angeles Regional - Chairman's Award
2009 Granite State Regional - Engineering Inspiration Award
2007 Los Angeles Regional - Engineering Inspiration Award
2006 Southern California Regional - Regional Champions
Unread 02-02-2008, 22:28
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Re: peltier coolers
Don't see why not, but why don't you just use the fans supplied?
Re: peltier coolers
thanks
Follow the flowchart (last page of Section 8 of the Game Manual. If it violates any of the rules, you cannot use it.
(The reason I give this response is that I am not exactly sure what a Peltier cooler is, or what the Peltier effect is. I have heard of both.)
Unread 02-02-2008, 22:56
jollyroger1210's Avatar
jollyroger1210 jollyroger1210 is offline
FRC #2539 (Krypton Cougars)
jollyroger1210 is an unknown quantity at this point
Send a message via AIM to jollyroger1210
Re: peltier coolers
I would assume one would be able to, but they do AFAIK, consume huge amounts of power. Also, like a/c units, they don't create cold,they simply move heat. Where do you plan on geting a small cold plate? I've seen small (3x4 maybe) that are used in CPU and GPU coolers.
CAPS LOCK: IS IT THE KEY TO SUCCESS, OR IS IT CRUISE CONTROL FOR COOL?
Unread 02-02-2008, 23:15
GUI GUI is offline
AKA: Gary
FRC #4183 (Bit Buckets)
GUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to behold
Send a message via Yahoo to GUI
Re: peltier coolers
What i would like to know is how/why you found a need for such a device on a FIRST robot? There isn't any part i can think of that would require a surface to be cooled.
Unread 03-02-2008, 01:04
Jared Russell's Avatar
Taking a year (mostly) off
Re: peltier coolers
I don't know why on Earth you'd need a peltier...but just keep in mind that a peltier is essentially a "cold" plate on one side and a "hot" plate on the other. You're still going to need quite a fan in order to dissipate the heat from the hot side.
Unread 04-02-2008, 18:01
Re: peltier coolers
Although these cells do appear to make it through the flow chart, your inspector will need to know a few things before allowing them in the inspection process. For instance, I would want to know the full ratings of the device you are using, what you used to attach the device (adhesive, thermal conducting grease etc.) how it is controlled (if it is) and what the maximum temp the "hot" side will achieve during operation.
When considering cooling devices for an FRC robot, it would seem that the low temperature achieved in a two minute match would not be useful for any cooling needs you might have. For those devices that are capable of a 200 degree max temp during operation, I would think that would cross the boundary into unsafe territory for the participants.
The GDC has the final say on these issues, so I must recommend you post to the Q&A for a ruling.
