Go to Post All labor is donated by the webmaster "Brandon". - Mike Martus [more]
Unread 04-02-2008, 18:51
ALIBI's Avatar
ALIBI ALIBI is offline
FRC #0141
Team Role: Parent
ALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to all
Re: CRIMP SLEEVES
The Anderson cable half that connects to the battery can not be extened. Since the weight is not counted in the robot weight, they do not want a couple extra pounds or more showing up via #6 wire. The Anderson cable half that feeds your electrical system could be extended, but I agree with Al S. that you should make your own cables.
Sprockets and Crimp connectors archiver 2000 1 24-06-2002 00:26
What's up the Rambots' sleeves nowadays? archiver 2000 0 24-06-2002 00:01
