Go to Post The most important part of successfully solving the problem is to understand what the problem is. Elegance in engineering comes from "optimizing" your solution, not solving problems that don't really exist. Fulfill your requirements, meet your goals... - JVN [more]
Unread 04-02-2008, 18:53
edgar_amaro edgar_amaro is offline
FRC #2582 (Pantherbots)
Team Role: Student
edgar_amaro is on a distinguished road
AIR COMPRESSOR !!!
ok... so we are building our robotic ARM... and we are using the air compressor that came with the KOP... but we are just getting 20 psi
do you think that it is our compressor that is faulty or is that right ????
Unread 04-02-2008, 18:54
Re: AIR COMPRESSOR !!!
Check for leaks first. A leak anywhere in the system will affect the whole system. Non-square tubing ends count as a leak.
Unread 04-02-2008, 18:56
Team Role: Student
yeah !!! we checked for that and well at first we got 10 psi and now its 20 psi
Unread 04-02-2008, 19:04
Are you hearing any hissing? If so, one of the relief valves has probably tripped.
Also check the code for the compressor. If it's set for the wrong pressure...
Unread 04-02-2008, 19:06
johnnysanchez johnnysanchez is offline
FRC #2582
johnnysanchez is an unknown quantity at this point
iam glad iam not doing that stuff!!!!!
Unread 04-02-2008, 19:31
Team Role: Student
how do we check the code for the compressor...
we use easy C...
Unread 04-02-2008, 19:35
Start with this thread to find where to look and what to look for.
Unread 04-02-2008, 19:39
Team Role: Student
thanks man !!!! this is our rockie year & we are doing our best !!!
Unread 04-02-2008, 20:29
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Are you reading off a regulator gauge or just a gauge? Make sure you've hooked your regulators on the right way.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 04-02-2008, 20:44
CraigHickman
Posts: n/a
I know our team has received an improperly configured safety release valve in the past... If, and only if you can't fix it elsewhere, you may want to examine this. However, it should be the LAST thing to check!
Unread 04-02-2008, 21:13
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
The code for the compressor should just check whether the pressure switch has activated or not. The program cannot change what pressure activates the switch.
So if the compressor is running and you are only seeing 20psi and you have your regulator in the system here are some things to check:
1. Leaks as already mentioned. Since you are only seeing 20 psi, your leak would be large enough to hear. Also make sure all of your tubing is pressed firmly into the fittings. As mentioned above non-square tubing ends will prevent tight seating so check that. Also give each fitting a little tug to make sure the tube is in.
2. Make sure you have your regulator set up correctly. If you look closely at it, you will notice an arrow that indicates which way the air should flow. I believe the regulators have 4 ports. Input from the air tanks should go on the starting side of the arrow. Output from the regulator on the end of the arrow. Pressure gage on the top. Plug on the bottom. Finally, turning the regulator clockwise will bring the working air pressure up.
Unread 05-02-2008, 00:43
gburlison gburlison is offline
gburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to all
My memory is a little fuzzy, but I seem to remember that if you have the power leads reversed (red to negative and black to positive) the compressor will run, but it gets real hot and does not put out much pressure. Be sure and check the polarity of the voltage at your compressor.
Gordon Burlison - Mentor
662/Rocky Mountain Robotics
"Every silver lining's got a Touch of grey - Robert Hunter"
"No sense in being pessimistic, it wouldn't work anyway"
Air Compressor Question Jrocklz Pneumatics 4 17-01-2008 21:36
Air Compressor Wireing question Bochek General Forum 7 11-01-2007 21:34
Off robot air compressor sanddrag Rules/Strategy 52 11-01-2007 15:11
Looking for Air compressor part SteveC116 Inventor 3 01-02-2003 20:53
Air Compressor geo Technical Discussion 4 06-02-2002 22:52
