Go to Post FIRST people are just wierd like that. We get drawn to places in the middle of the desert as long as we know there will be more people like us there. - sanddrag [more]
Unread 21-01-2008, 11:30
sonicx059's Avatar
sonicx059 sonicx059 is offline
Philosophy or Robotics? BOTH.
FRC #1439 (ROBO Raiders)
sonicx059 will become famous soon enough
Send a message via Yahoo to sonicx059
rule on victors
I am trying to find out if there is a rule that says we need a victor on each CIM motor.
The right path is my path.
Knowing is not enough, you must apply.
Willing is not enough, you must do. ~Bruce Lee
A man is bound only by the chains that he binds himself with. ~Demario Mitchell
Unread 21-01-2008, 11:39
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Re: rule on victors
I'm not sure what the rule number is but you NEED a victor per CIM. The CIMs draw too much current to run more then one per Victor / 40A Fuse.
dtengineering's Avatar
AKA: Jason Brett
Re: rule on victors
Yes:
<R56> Each power regulating device (Victor speed controller or Spike relay) shall control one and only one electrical load (motor, actuator or compressor). Multiple low-load devices (e.g. pneumatic valves) may be connected to relay modules (but only one motor may be
connected to each relay module).
Jason
Unread 21-01-2008, 12:00
sonicx059's Avatar
Re: rule on victors
Originally Posted by dtengineering View Post
Yes:
Jason
Thank you all for the information.
Unread 21-01-2008, 12:01
sonicx059's Avatar
Re: rule on victors
I send you my thanks also.
Unread 04-02-2008, 21:46
aaeamdar's Avatar
aaeamdar aaeamdar is offline
Post-A-Holic
AKA: Paul Dennis
FRC #1719 (The Umbrella Corp)
aaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant future
Re: rule on victors
I understand Rule R56, I've read it and thought I understood it, until my dad came across this in the inspection checklist:
Originally Posted by InspectionChecklist
Motors can only be driven by one Victor (although a Victor can drive more than 1 motor).
This seems to directly contradict Rule R56. Any insight?
-Paul
Unread 04-02-2008, 22:05
Re: rule on victors
Originally Posted by inspectionchecklist
<R86>Motors can only be driven by one Victor (although a Victor can drive more than 1 motor).
-Paul
I thought that might be a holdover from other years, as that has happened before. However, 2007-2005 had a rule that stated
No more than one motor may be connected to each Speed Controller.
This is worth mentioning in Q/A so that it can be fixed.
Unread 04-02-2008, 22:07
GaryVoshol's Avatar
Cogito ergo arbitro
Re: rule on victors
-Paul
Yep, courtesy of Q&A: http://forums.usfirst.org/showthread.php?t=8560
Inspection sheet will be corrected.
(since 2004)
Unread 04-02-2008, 22:08
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
Re: rule on victors
In 2007, the rules were written to allow more than one motor per Victor (2007 rule <R91>). Rule <R56> was added/changed for 2008 to clearly prohibit this.
That was my fault for not catching this earlier in the season. A Q&A response posted today brought this to my attention. As stated by the GDC, Section 8 always overrides the checklist. Regardless, a new checklist will be created with this update.
Thanks!
Russ Beavis
Chief Inspector
Unread 04-02-2008, 22:14
Re: rule on victors
Going back through the rules - 2005 and 2006 explicitly stated only one motor per Victor (<R77> in 2005 and <R86> in 2006) but 2007 was a bit more forgiving with <R91>.
I try to keep up with Section 8... I promise
Russ Beavis
Chief Inspector
Unread 06-02-2008, 19:27
TheNotoriousKid's Avatar
TheNotoriousKid TheNotoriousKid is offline
AKA: Shane O
FRC #0025 (Raider Robotix)
TheNotoriousKid is just really niceTheNotoriousKid is just really niceTheNotoriousKid is just really niceTheNotoriousKid is just really niceTheNotoriousKid is just really nice
Send a message via AIM to TheNotoriousKid
Re: rule on victors
This thread was extremely informative, I've never thought about this. We usually throw extra "vicS" in just to be save and have an easy way to swap speed controllers in case of emergency
Unread 06-02-2008, 19:53
Torboticsmember's Avatar
Torboticsmember Torboticsmember is offline
AKA: Alan Bartow
FRC #2080 (Torbotics)
Team Role: Driver
Torboticsmember is a name known to allTorboticsmember is a name known to allTorboticsmember is a name known to allTorboticsmember is a name known to allTorboticsmember is a name known to allTorboticsmember is a name known to all
Re: rule on victors
I know this just sounds real dumb, but I thought that a Spike and a relay module are the same. Is this completely wrong, if so what is the relay module and where can I get one, if we need it
Unread 06-02-2008, 21:35
usbcd36's Avatar
usbcd36 usbcd36 is offline
AKA: "DOS"
FRC #2399 (The Fighting Unicorns)
usbcd36 is a jewel in the roughusbcd36 is a jewel in the roughusbcd36 is a jewel in the rough
Re: rule on victors
Yes, Spikes and relay modules are the same thing. Well, sort of. Spikes are a type of relay module, but they're the only type that you can use on a FIRST-legal robot.
Unread 10-02-2008, 00:03
Re: rule on victors
A Spike is the IFI model name for the First legal relay module. They are one and the same.
splicing victors h0x4r Electrical 6 19-02-2005 15:46
Calibrating Victors SpaceOsc Control System 27 19-11-2004 07:59
Rule G11 and Springs Rule mtaman02 Technical Discussion 3 23-01-2004 17:43
victors great_one411 Electrical 4 06-02-2003 09:08
Flakey Victors archiver 1999 4 23-06-2002 21:58
