Go to Post Don't fix mechanical problems with software, ever. - Chris is me [more]
Unread 04-02-2008, 22:22
EFastring EFastring is offline
AKA: Eric Fastring
FRC #2078 (Robotic Wolves)
EFastring is an unknown quantity at this point
Gyro problems, crossposted from Electrical
in this thread I asked about testing the kit gyro and was given a programming answer, so I will continue my programming question here.
I am wanting the easiest way to test my gyro to see if it is dead.
I have the kit gyro hooked up with a PWM cable, with the white cable connected to TW(twist), the black cable connected to GB (ground), and the red cable to 5R (+5V). I plug it into the Robot Controllers Analog input 1 with the colors corresponding to those on the inputs.
In my code, under user_routines.c I have added the following
double yawtest = 0;
yawtest = Get_Analog_Value( rc_ana_in01 );
printf("yawtest %d\r", yawtest);
I get a number back that does not change (17535).
I am definitely hooked to TW (twist) and not RW (relative temperature).
At this point I am really just wanting to see a number that changes when I move the gyro chip. Am I doing something wrong or do I have a dead gyro? Is there an easier way to see if it is dead?
gyro and accelerometer problems paulcd2000 Programming 6 16-02-2008 15:17
Gyro Autonomous Problems cprogrammer Programming 5 23-03-2007 14:28
Problems with the Gyro Guy_E Programming 21 04-12-2006 17:23
Problems with the gyro Conan Programming 7 06-02-2006 01:45
Gyro Code Problems railerobotics Programming 8 27-01-2006 10:45
