Go to Post It all depends on which box your trying to think outside. - ItsPat [more]
Unread 04-02-2008, 22:32
Mikhail_Pham Mikhail_Pham is offline
Mikhail_Pham is an unknown quantity at this point
How would you power the operator interface
Without using an AC adaptor or any tethering?
Thank you in advance.
Unread 04-02-2008, 22:36
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: How would you power the operator interface
At competition, the OI is powered through the Competition Port. However, plugging random things into this port is not recommended.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 04-02-2008, 22:39
DonRotolo's Avatar
Back to humble
FRC #0832
To answer your question directly, you must supply power in some way. You can use a battery of the proper voltage, an AC adaptor, or tether it to a robot controller. That's about it for choices.
Don
Unread 04-02-2008, 23:07
AdmiralAllen's Avatar
AdmiralAllen AdmiralAllen is offline
Master of Computers and Robots
AKA: Allen Worcester
FRC #1662 (Raptor Force Engineering)
AdmiralAllen will become famous soon enough
we actually wire a 9 volt battery to a dc plug like the one on the power pack.....(you can get em at radio shack or a hooby shop)
and just plug it in......works great!
Unread 04-02-2008, 23:33
Anything from 9-12 volts DC will work. Last year, I removed an appropriate connector from an old, dead AC adapter and wired it up to an old, not-quite-dead-yet 12 volt drill battery. It successfully powered an OI for many minutes at a time.
Unread 04-02-2008, 23:39
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Would it be ok to put a fuse and adapter plug on an Anderson connector and plug it into a spare big gray robot battery?
Unread 05-02-2008, 00:13
that'd prolly do it too
Unread 05-02-2008, 00:15
popo308's Avatar
popo308 popo308 is offline
AKA: Brent
FRC #1625 (Winnovation)
popo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to all
Send a message via AIM to popo308
We just power it trough our competition controller...
(it dos void the warranty so make sure you know what your doing!)
Unread 05-02-2008, 00:28
Binome's Avatar
Binome Binome is offline
Programmer/Electronics/CAD
AKA: Patrick
FRC #2273 (SHIM)
Binome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of light
What i'd like to develop would be a DC-DC converter to drive the OI with a good 3.7v li-ion cell. Keeps things light, small, and compact, and delivers one heck of a kick. Too bad I can't replace that heavy backup battery with a smaller cell for the chicklet and robot controller in competition
Unread 05-02-2008, 00:37
That should work fine. For sizing the fuse, keep in mind that the OI wants about 1.5 amps of current.
Unread 05-02-2008, 01:10
Colin's Avatar
Colin Colin is offline
FRC #0254
Colin has a reputation beyond reputeColin has a reputation beyond reputeColin has a reputation beyond reputeColin has a reputation beyond reputeColin has a reputation beyond reputeColin has a reputation beyond reputeColin has a reputation beyond reputeColin has a reputation beyond reputeColin has a reputation beyond reputeColin has a reputation beyond reputeColin has a reputation beyond repute
Here is a white paper you might find useful, worked for us:
http://www.chiefdelphi.com/media/papers/1559
Unread 05-02-2008, 13:34
Phyrxes's Avatar
Phyrxes Phyrxes is offline
Has done the math, have you?
AKA: Dave Button
no team (No Team, Changed Schools)
Phyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant future
Nice, I would have never thought to look for that and it will make testing outside much easier.
How do you wire up the Operator Interface? iPilipino Electrical 6 22-01-2008 00:22
How would I interface a flash drive to the RC? JBotAlan Technical Discussion 42 31-01-2007 15:24
How do you bypass the Operator Interface? jskene Programming 4 31-05-2006 17:50
Operator Interface power ISSUE kacz100 Technical Discussion 11 27-02-2004 13:46
operator interface power supply hi_im_sean General Forum 1 05-02-2003 14:50
