Go to Post Welcome to ChiefDelphi.com. Get ready for the craziness. - Andy Baker [more]
Go Back   Chief Delphi > Old Forum Archives > 2000
Unread 23-06-2002, 23:09
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
Drill Gearboxes
Posted by Dan.
Student on team #10, BSM, from Benilde-St. Margaret's and Banner Engineering.
Posted on 2/13/2000 3:43 PM MST
Two questions:
1. What exactly is the purpose of those 'anti-reverse' pins in the drill gearboxes (besides breaking)?
2. Does anyone know if these are common in other cordless drill gearboxes, specifically in DeWalt brand drills?
Thanks for your help, :-Dan
#0047 (ChiefDelphi)
Keyless Chucks
Posted by Dodd Stacy.
Engineer on team #95, Lebanon Robotics Team, from Lebanon High School and CRREL/CREARE.
Posted on 2/13/2000 4:43 PM MST
In Reply to: Drill Gearboxes posted by Dan on 2/13/2000 3:43 PM MST:
: Two questions:
: 1. What exactly is the purpose of those 'anti-reverse' pins in the drill gearboxes (besides breaking)?
: 2. Does anyone know if these are common in other cordless drill gearboxes, specifically in DeWalt brand drills?
: Thanks for your help, :-Dan
Dan,
I think the basic reason is so that you can operate the 'keyless chuck' by hand (in either direction). When you attempt to overdrive the drill/gearbox (in either direction) to tighten or loosen the chuck, the 'anti-reverse pins' lock up the gearbox to give you something to torque against. I assume all drills (cordless or not) that use a keyless chuck incorporate anti-reverse pins, regardless of brand.
When you throttle down on a traveling robot (forward or backward), the momentum of the robot 'overdrives' the motor, causing the pins to lock up and pitting the entire kinetic energy of the 130 lb robot against the torsional strength of a bunch of plastic gears and housing pieces trying to resist. The only thing that prevents the entire thing from shattering on the first try is that the wheels slip on the carpet and limit the peak torque.
TAKE THE PINS OUT.
Dodd
[IMG] code is Off
Portable cordless drill press Gui Cavalcanti Technical Discussion 25 03-08-2003 22:21
drill motor mounts- again Jeff Sharpe Motors 6 07-04-2003 23:20
Emergency drill trade/sell Anarkissed General Forum 3 16-02-2003 22:37
Q&A Discuss: HOT drill motors CD47-Bot Extra Discussion 1 27-01-2003 13:31
