Go to Post If you base a team on how well you do on the field you have a much harder time winning. - Bob Steele [more]
Unread 04-02-2008, 22:16
eshteyn's Avatar
eshteyn eshteyn is offline
WOOPS! shorted the deep cycle batt.
AKA: the supply seargent, Eugene
FRC #0375 (the robotic plague)
eshteyn is just really niceeshteyn is just really niceeshteyn is just really niceeshteyn is just really niceeshteyn is just really nice
Send a message via AIM to eshteyn Send a message via Yahoo to eshteyn
pic: Part of our 4D navigation system
Unread 04-02-2008, 22:19
Stuart's Avatar
Stuart Stuart is offline
#include coffee.h
FRC #1745 (P51- Mustangs)
Stuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond repute
Send a message via AIM to Stuart
Re: pic: Part of our 4D navigation system
4d . . I can see how you might be able to track objects over time . . but I'm trying to figure out how you'll change your robots 4th dimensional velocity from 1 second per second to any thing else . . well with using COTS parts.
Proud mentor of Team #1745 the P-51 Mustangs
If at first it doesn't work, use a hammer.
If that doesn't work, use a bigger hammer.
Unread 04-02-2008, 23:21
Happy Birthday! Diriye Diriye is offline
Diriye has much to be proud ofDiriye has much to be proud ofDiriye has much to be proud ofDiriye has much to be proud ofDiriye has much to be proud ofDiriye has much to be proud ofDiriye has much to be proud ofDiriye has much to be proud of
Yes!!!! I suggested this a couple of days to our team. Now, there's visual proof it can be done!!!
But I was wondering, what's the range of the NXT ultrasound sensor?
"The difference between a successful person and others is not a lack of strength, not a lack of knowledge, but rather a lack in will."
Unread 04-02-2008, 23:34
David's Avatar
David David is offline
FRC #1647 (Iron Devils)
David is a jewel in the roughDavid is a jewel in the roughDavid is a jewel in the roughDavid is a jewel in the rough
Send a message via AIM to David
I think they might win an innovation award if they manage to essentially time travel . a devise that runs off a 12 volt battery, and weights less that 100 pounds, and is controller by 2 small processors, impressive to say the least. Also, since its 4-D it will fly. (Note: yes i know that acceleration disrupts the flow of space-time, but the original post inferred true navigation of 4 dimensions not minute undetectable changes)
Unread 05-02-2008, 00:07
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Theoretically, anywhere from 0 to 100 inches. Practically, it's "accurate" (depending on your definition of accuracy) from between about 2 to 40ish inches.
Unread 05-02-2008, 00:30
Woody1458's Avatar
Woody1458 Woody1458 is offline
AKA: Woody Jansen
FRC #1458 (Danvillans)
Woody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to behold
Send a message via AIM to Woody1458
I dont think he meant 4D as you guys are thinking it. The clue was Part of our 4d navigation system. As in the system has many parts, specifically 4 parts. This is one dimension of a four dimension sensor system. (gyroscope, accelorometer, sonar, gear tooth)
"Everything we produce is made of: Duct Tape, zip ties, and hope" - Christian Allinson 1458
Anyone can watch Westcoast Choppers and see adults build things, but FIRST is great because it encourages kids to do the building and adults to do the watching.
GO DANVILLANS!!
Unread 07-02-2008, 16:20
jktheta's Avatar
jktheta jktheta is offline
AKA: Justin
FRC #1370 (Blue Charge)
jktheta is an unknown quantity at this point
Wait...
How are the robot and NXT connected?
Inertial Navigation System - Has it Been Done? DragonRagnarok Programming 8 24-01-2008 04:00
pic: A closup view of our prototype worm-crab drive system. AndyB Extra Discussion 6 20-01-2008 00:02
Name our Battle bot part 2 Greg Needel Chit-Chat 14 23-09-2005 18:08
Name / logoize our Robot Part 3 Alex Cormier Chit-Chat 12 03-06-2005 23:51
Inertial Navigation System CyberWolf_22 Electrical 19 04-12-2003 17:27
