Go to Post It would be a (relatively) level* playing field *...though it seems like the actual field will be anything but level. - Jacob Bendicksen [more]
Unread 04-02-2008, 13:20
Cassini Probe Cassini Probe is offline
Cassini Probe is an unknown quantity at this point
IR Board Programming
Okay, dumb question. What do you use to program the Ir board besides the programming switch. Cables or an EEprom unit?
Unread 04-02-2008, 13:30
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Re: IR Board Programming
You just use the button on the IR board to program the IR board. You have to program it to work with your RC by programming the RC. This has been discussed many times, so just search around and see what you get.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 04-02-2008, 15:54
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
I believe that 5 pin header is used to program the PIC on the IR board but I'm not sure why you would want to do that.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 04-02-2008, 16:01
You don't actually "program" the IR sensor board in the sense of modifying its software. You merely "train" it to recognize modulated IR signals. All you need in order to do that is a power source, an IR transmitter (i.e. remote control), and the pushbutton switch on the board.
Unread 04-02-2008, 18:49
team877's Avatar
team877 team877 is offline
FRC #0877 (Cub Robotics)
team877 is an unknown quantity at this point
make sure you ground your IR board to the robot and not the backup battery. If you do your program won't work.
Unread 05-02-2008, 00:31
code_lacky code_lacky is offline
AKA: Mark
FRC #0840
code_lacky is an unknown quantity at this point
team877 if that is true I have to thank you for saving me countless hours of painful debugging because I was wondering how such a simplistic test code I wrote could fail so miserably
Programming the Infrared board BradAMiller Sensors 10 06-02-2008 22:47
Easy C programming for the GTS board Pi Boy Programming 2 23-01-2008 23:38
pic: Programming prototyping board Andrew Schuetze Extra Discussion 3 08-12-2007 18:30
Lights in Joystick board or control board rcubes85 Control System 15 26-02-2005 23:40
Perf Board = BS2-IC Carrier Board? indieFan Electrical 2 16-09-2004 08:28
