Go to Post One wouldn't want to keep the red herring in hand, that gets kind of stinky. - GaryVoshol [more]
Unread 05-02-2008, 07:22
Re: Limit Sensors for Lift
Limit switches do not have to live in the path. You can place them next to a moving object so that a piece of the your moving part, swipes across the actuator. You can also add something to your cable (like a washer or crimp on sleeve) so that when the cable gets to a particular point, the switch is pressed.
Time limit for animation???? gimpnub 3D Animation and Competition 24 22-02-2008 17:09
Scissort Lift vs. Crane vs. 4-Bar Lift vs. Gas Springs AdamC Technical Discussion 31 20-01-2008 18:49
Using a limit switch to limit motion ManicMechanic Programming 16 20-12-2007 00:54
Limit Switch for PCM GeorgeC Programming 4 16-02-2007 13:21
Limit on sensors Gusman1188 Technical Discussion 13 16-02-2003 23:24
