Go to Post I think FIRST is probably close to the farthest you can get from 'gangsta', outscored only by the math team. - Tom Bottiglieri [more]
Unread 05-02-2008, 09:38
EFastring EFastring is offline
AKA: Eric Fastring
FRC #2078 (Robotic Wolves)
EFastring is an unknown quantity at this point
Re: Gyro problems, crossposted from Electrical
I made the changes above to make my variable an int, but saw no difference.
Does anyone have any suggestions for testing our kit gyro to see if it is alive? Is there a way to do it with a voltage meter?
does Get_Analog_Value( rc_ana_in01 ) return a value that should change when the gyro chip is rotated, or do you have to initialize the gyro before it will function at all?
gyro and accelerometer problems paulcd2000 Programming 6 16-02-2008 15:17
Gyro Autonomous Problems cprogrammer Programming 5 23-03-2007 14:28
Problems with the Gyro Guy_E Programming 21 04-12-2006 17:23
Problems with the gyro Conan Programming 7 06-02-2006 01:45
Gyro Code Problems railerobotics Programming 8 27-01-2006 10:45
