Go to Post Oh no, do I see a new reality TV show coming? "Dancing with the FIRST Stars"??? :ahh: - KathieK [more]
Unread 04-02-2008, 18:49
spc295 spc295 is offline
FRC #0295 (Renevatio)
spc295 is a splendid one to beholdspc295 is a splendid one to beholdspc295 is a splendid one to beholdspc295 is a splendid one to beholdspc295 is a splendid one to beholdspc295 is a splendid one to behold
Exclamation OI Problems
When we tether our OI to our robot, there is a problem. The green power light comes on on the OI, but nothing else. Usually the 4 digit display shows some characters when initializing, but now it doesn't. Also, on the robot controller, the Radio modem is flashing red, even though no radio is connected. When running a program instructed to print to screen, we get nothing. Is there something I am missing?
295 Team Captain
Unread 04-02-2008, 18:55
GrammarNazi GrammarNazi is offline
FRC #2952
GrammarNazi is on a distinguished road
Send a message via AIM to GrammarNazi
Re: OI Problems
are you sure all the cables are in tight and in the right place? We plugin everything when we do it, tether, radios, and program cable
First one to reply gets a cookie!!!
Unread 04-02-2008, 19:00
Re: OI Problems
Our OI isn't even initializing. Usually, it displays a bunch of things, and ends with displaying our team number. Now, it displays nothing. Blank. It is recieving power through the tether, as indicated by the green power LED, but beyond that, nothing happens.
295 Team Captain
Unread 04-02-2008, 19:56
Re: OI Problems
You didn't happen to hook anything up to the Competition Port did you?
Unread 04-02-2008, 20:37
Miner Miner is offline
AKA: Jacob Miner
FRC #2077 (Laser Robotics)
Miner is on a distinguished road
Re: OI Problems
First of all, make sure that you are using the RED tether cable, it wont plug in if you are not using it.
Also, it shouldnt matter if your Radios are plugged in or not either on the OI or the RC. You could probably leave them in and it wont make a difference.
Other than that the only thing that I could think of would be to make sure that your team number is programmed into the OI and make sure that the RC is reading that number. We had a problem with that too, we tried to run 3 bots at once and it didn't work until we put them all on different channels and numbers.
Good Luck!
Jacob
Unread 04-02-2008, 20:42
Re: OI Problems
No. Nothing is in the competition port.
295 Team Captain
Unread 04-02-2008, 20:44
Re: OI Problems
295 Team Captain
Unread 04-02-2008, 20:51
AKA: Jacob Miner
Re: OI Problems
Does it work if you use the radio w/o the tether?
Unread 04-02-2008, 22:07
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Re: OI Problems
I'm not sure if this will work, but last time I uploaded the Master Code to the RC it asked me to connect the OI via tether. Maybe it loads the Master Code to the OI as well.... May be something to try.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 04-02-2008, 22:37
Re: OI Problems
Have you tried powering the OI with it's own power supply?
It could be low battery power from the RC through the tether.
The OI should do its normal countdown when powered up.
You won't get any response out of the RC until it successfully establishes communication with the OI. From your description the RC is behaving as expected, just the OI is not.
Unread 05-02-2008, 09:42
whosdadog's Avatar
whosdadog whosdadog is offline
AKA: Jon
whosdadog is an unknown quantity at this point
Re: OI Problems
Thanks for your help. It seems the problem has resolved itself.
IR Problems Tottanka Electrical 3 13-01-2008 15:07
Labview problems and code problems ajsetter Programming 25 18-01-2006 17:07
Problems muy dificil Programming 5 26-10-2005 17:10
Problems- archiver 1999 0 23-06-2002 23:00
