Go to Post Don't fight success. - Al Skierkiewicz [more]
Unread 05-02-2008, 12:35
Commander Gix Commander Gix is offline
FRC #2668
Commander Gix is an unknown quantity at this point
Question on Joysticks in Hybrid mode
I was wondering if the Joystick is even able to be powered when the Robot is set to run in Hybrid mode? Or Is it going to be powered and just sit there waiting. Also, Is the Hybrid IR Code going to run in the Autonomous Mode? Just wondering how the rules define this...
High Commander and Founder Of The BeaverBacks.
Overseer Of TBB Covert Ops Squadron. AKA. Cobra Squadron.
Cobra!
TBB FTW
Unread 05-02-2008, 12:40
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
Re: Question on Joysticks in Hybrid mode
Commander Gix,
The joysticks will be connected to the Operator Interface and you won't be able to touch them during Hybrid Mode (must stay behind the line).
Manoel Flores da Cunha
Brazilian Machine
Team # 383
Unread 05-02-2008, 14:43
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
In autonomous mode the OI ignores the joystick feedback.
The IR Sensor is hooked directly to the RC to you are by-passing the OI.
Unread 05-02-2008, 16:10
Hybrid Mode is just this year's name for the controller's Autonomous Mode. Any code you want to be running during Hybrid Mode will need to be put in whatever Autonomous function your program framework provides. IFI's 2007 default code has User_Autonomous_Code(). I think the WPILIB and easyC equivalent is just called Autonomous(). Kevin Watson's C18 3.0-compatible code provides Autonomous() and Autonomous_Spin().
Unread 05-02-2008, 16:38
RyanW RyanW is offline
FRC #0449 (Blair Robot Project)
RyanW has a spectacular aura aboutRyanW has a spectacular aura about
Yes, the joystick is powered. The OI is plugged into the competition interface thing the whole time. However, at the beginning of the autonomous code, all of the OI are set to neutral (you can't change that part), and so are of no use to you. You can, however, receive input from whatever you have on your robot, including onboard digital I/O switches if you want to switch between autonomous modes beforehand. You can also get sensor input and send output to motors as normal.
Hybrid mode? Mrtrom General Forum 20 21-01-2008 07:11
Hybrid Mode Rule Question CollmandosGrl Rules/Strategy 1 20-01-2008 07:36
Hybrid mode question. ks_mumupsi Rules/Strategy 13 14-01-2008 22:43
<G40> in hybrid mode clydefrog88 Rules/Strategy 2 10-01-2008 16:01
Hybrid mode issue Los Frijoles General Forum 2 07-01-2008 18:52
