Go to Post The Lord of the Bots.... - Bob Steele [more]
Unread 05-02-2008, 15:55
2526 2526 is offline
Crimson Robotics
FRC #2526 (Crimson Robotics)
2526 is an unknown quantity at this point
Re: Help with Kevin Watson's 2008 code
The project did build but as soon as I added pwm01 = p1_y; It would not build as shown below.
void Teleop(void)
pwm01 = p1_y;
// example code to test your gyro and encoder(s)
long Encoder_Count;
static unsigned int i = 0;
static unsigned int j = 0;
int temp_gyro_rate;
long temp_gyro_angle;
int temp_gyro_bias;
i++;
j++; // this will rollover every ~1000 seconds
// enable this block of code to test your gyro
if(j == 10)
printf("\r\nCalculating Gyro Bias...\r\n");
if(j == 38) // let the gyro stablize for a second before starting a calibration
// start a gyro bias calculation
Start_Gyro_Bias_Calc();
if(j == 191) // allow calibration routine to run for four seconds
// terminate the gyro bias calculation
Stop_Gyro_Bias_Calc();
// reset the gyro heading angle
Reset_Gyro_Angle();
temp_gyro_bias = Get_Gyro_Bias();
printf("Gyro Bias=%d\r\n", temp_gyro_bias);
if(i == 35 && j >= 191)
temp_gyro_rate = Get_Gyro_Rate();
temp_gyro_angle = Get_Gyro_Angle();
printf(" Gyro Rate=%d\r\n", temp_gyro_rate);
printf("Gyro Angle=%d\r\n\r\n", (int)temp_gyro_angle);
// enable this block of code to test your encoder(s)
if(i == 37 && j >= 191)
Encoder_Count = Get_Encoder_1_Count();
printf("E1=%d\r\n",(int)Encoder_Count);
Encoder_Count = Get_Encoder_2_Count();
printf("E2=%d\r\n",(int)Encoder_Count);
Encoder_Count = Get_Encoder_3_Count();
printf("E3=%d\r\n",(int)Encoder_Count);
Encoder_Count = Get_Encoder_4_Count();
printf("E4=%d\r\n",(int)Encoder_Count);
Encoder_Count = Get_Encoder_5_Count();
printf("E5=%d\r\n",(int)Encoder_Count);
Encoder_Count = Get_Encoder_6_Count();
printf("E6=%d\r\n\r\n",(int)Encoder_Count);
// reset the loop counter
if(i >= 38)
i = 0;
// enable this to use IFI's default robot code
// Default_Routine(); // located in ifi_code.c
// update the state of the LEDs on the operator interface
Update_OI_LEDs(); // located in ifi_code.c
Unread 05-02-2008, 16:09
eaglesfan10's Avatar
eaglesfan10 eaglesfan10 is offline
FRC #1647 (Iron Devils)
eaglesfan10 is an unknown quantity at this point
void Teleop(void)
pwm01 = p1_y;
long Encoder_Count;
int temp_gyro_rate;
int temp_gyro_bias;
i++;
if(j == 10)
Reset_Gyro_Angle();
if(i >= 38)
i = 0;
You need to put it AFTER your declarations. Put it after this line:
int temp_gyro_bias;
Unread 05-02-2008, 16:53
Crimson Robotics
Thanks for the help we'll try that please check back as I'm sure we'll have more questions
	pwm01 = p1_y;
	long Encoder_Count;
	int temp_gyro_rate;
	int temp_gyro_bias;
In C, you have to put your code after all variable declarations. If you move pwm01 = p1_y; to the end of this block, it will compile.
Kevin watson's sensor code DustinB_3 Programming 3 30-01-2008 21:07
Problem compiling Kevin Watson's code Spencer E. Programming 2 07-01-2008 00:34
Trouble using Kevin Watson's Serial Code with Vex user API StargateFan Programming 3 13-01-2007 15:42
Kevin Watson's encoder code with RPM output MaxM Programming 2 05-02-2005 00:06
Kevin Watson's Kick-off Demo Code! Mr. Lim Programming 27 22-01-2005 03:38
