Go to Post My first instinct was inflatable clowns and 5 of them beating on the robots at all times, but then I thought, thats probably not right. - Dan Richardson [more]
Unread 05-02-2008, 17:00
Matt C's Avatar
Matt C Matt C is offline
FRC #1468 (J-Birds)
Matt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond repute
Send a message via AIM to Matt C
Re: Charging a System
If you have your system set up with everything hooked up except the compressor, you should be able to pressurize your system through your relief valve, (the 90 degree valve that should be connected somehow to your tanks.) Fill up your tanks until you reach 120 psi, then shut the valve and unplug your hose coming from the compressor.
Unread 05-02-2008, 17:03
REVving up for a new season
FRC #2848 (All-sparks)
be sure to remember that if you use this system the pneumatics manual still requires that you use the pressure switch and you get your power from your on board battery. so you will need to keep a clear shot to a spike and the digital input port on your controller if you use this method.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 05-02-2008, 17:14
Matt C's Avatar
FRC #1468 (J-Birds)
Yes, that would be necessary to comply with R94.
Unread 05-02-2008, 17:17
Magnechu Magnechu is offline
Student Strategist
AKA: Mike Fouchet
FRC #0870 (RICE)
Team Role: Tactician
Magnechu has a spectacular aura aboutMagnechu has a spectacular aura about
Send a message via AIM to Magnechu
The relief valve that we got in the KOP is not a 90 degree valve.
But if you do charge it through the relief valve how do you make a connection? Is it a quick connection or is it connected by thread?
Unread 05-02-2008, 17:20
Matt C's Avatar
FRC #1468 (J-Birds)
The system relief valve(the brass one with the black knob that is normally used to depressurize the system), not the compressor relief valve. I should have called it the "plug valve".
Unread 05-02-2008, 18:45
Zultraranger Zultraranger is offline
FRC #0870
Zultraranger will become famous soon enoughZultraranger will become famous soon enough
Could someone please elaborate on this subject? I am interested in knowing the connnection between the release valve and the offboard compressor.
Unread 05-02-2008, 21:08
in between teams
AKA: Luke Van Oort
We ran an offboard compressor setup last year, and if you look at this picture of that robot, you can see an example of the valve with a connection for the compressor. The valve is a little to the left of the orange tape measure near the bottom of the tower. It just has a quick-release connector on one end and has the other end connected to the rest of the pneumatics system. If the compressor is not attached, opening the valve allows the air in the system to vent; if the compressor is attached it allows the compressor to charge the system; and if the valve is closed it allows the system to retain air pressure.
Team 1219: 2009 - Mentor
Backup Battery Charging Circuit David55 Electrical 7 25-02-2007 23:37
Battery Charging Box MikeDubreuil Electrical 17 22-04-2004 21:38
Charging Batteries like_a_fox Electrical 10 15-03-2004 17:57
charging backup battery Max Lobovsky Electrical 6 12-03-2004 10:24
Battery Charging - Warning! sanddrag Technical Discussion 11 21-01-2004 00:10
