Go to Post FIRST is the only sort of competition that I've seen where somebody can win and the opponents can be genuinely happy for them. - RiceRobotica [more]
Unread 05-02-2008, 17:12
Derschatten Derschatten is offline
FRC #1203 (Pandemonium)
Derschatten is an unknown quantity at this point
How do I mount a geartooth sensor?
I only want to know which side of the black 4-pin module on the sensor has to be facing the gear on the robot. I already know how to wire it and how far away the geartooth has to be from the gear.
Thanks!
Unread 05-02-2008, 17:23
GrammarNazi GrammarNazi is offline
FRC #2952
GrammarNazi is on a distinguished road
Send a message via AIM to GrammarNazi
Re: How do I mount a geartooth sensor?
the side with sensor needs to face the gear (small black box)
First one to reply gets a cookie!!!
Unread 05-02-2008, 21:46
The flat face of the sensor is what goes next to the gear. If you're talking about the red GTS board from the Kit of Parts this year, there are mounting holes in the lexan plate of the ToughBox that put it in the proper location and orientation.
Unread 06-02-2008, 08:27
matrixrobotics matrixrobotics is offline
FRC #0179 (Children of the Swamp)
matrixrobotics is an unknown quantity at this point
My team did not mount the gear tooth sensor in the provided holes. It seemed to require adding fairly large (3/4"+) standoffs under the board. We elected to drill holes in the opposite plate which put the gear tooth right where it needed to be. We did have to mill a little bit out of the corner of the gearbox shell to allow the circuit board some clearance.
Charlie
Where to buy geartooth sensor dawilliams Kit & Additional Hardware 2 24-01-2008 00:07
How to Mount Things cjtenny General Forum 15 14-01-2008 12:30
Voltage regulator--how to mount? JBotAlan Electrical 17 10-05-2007 09:40
Mounting Geartooth sensor! AaronTeune Electrical 2 04-02-2007 01:34
GearTooth Sensor Destroying Hopes of Autonomous~!!!!!! Prgrmin' Programming 36 28-02-2006 19:07
