Go to Post Thank you for participating. It'd be a blank website without all of you. :) - Brandon Martus [more]
Unread 05-02-2008, 17:40
diesel's Avatar
diesel diesel is offline
FRC #2077
diesel has a spectacular aura aboutdiesel has a spectacular aura about
Question Bumper segments
We are helping a new team this year, and I believe we have run into a unique problem with bumpers.
None of the sides of the robot are six inches long (It's a 12 sided 'bot).
And the GDC seem very strict about not putting plywood into the corners.
So how do we build bumpers that are more than six inches long and do not have plywood in the corners. Even if we made two bumpers that each covered half the robot, those bumpers would have plywood in the corners.
How do we overcome the problem?
Design. Build. Dew.
Unread 05-02-2008, 17:44
GrammarNazi GrammarNazi is offline
FRC #2952
GrammarNazi is on a distinguished road
Send a message via AIM to GrammarNazi
Re: Bumper segments
you could just build four bumpers and make a square around it, im not really sure what you mean by plywood in the corners
First one to reply gets a cookie!!!
Unread 09-02-2008, 20:15
Browzilla Browzilla is offline
Fearless Leader
AKA: David Vriezen
FRC #2530 (Team Inconceivable)
Team Role: Electrical
Browzilla is on a distinguished road
Send a message via AIM to Browzilla Send a message via MSN to Browzilla
Re: Bumper segments
I believe your only real options are redoing the frame of your robot, or having the bumpers securely fastened in a square shape, entirely ignoring the other 8 sides. Securely fastening them may be a challenge though.
Unread 09-02-2008, 20:28
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Re: Bumper segments
Post a picture here and you may get more help.
-Dustin Benedict
Unread 09-02-2008, 20:55
dtengineering's Avatar
AKA: Jason Brett
Re: Bumper segments
The situation may not be as dire as it sounds. I believe this Q&A helps explain what, exactly, is meant by no plywood in the corners. So long as your "corner" is covered by a full thickness of pool noodle and fabric, you are okay.
The rule was worded (and diagrams drawn) with rectangular robots in mind. You may (and please remember, this isn't the Q&A, so please get a ruling on this before you ship your robot) be able to construct the bumpers in such a way that you have one pool noodle length covering three, four, or more sides of your robot by using a segmented and mitred piece of plywood. As the outer edge of the plywood would form a continuous edge, which is continually covered by a noodle and fabric, when bolted to the robot, this may be considered a continuous, rather than segmented, bumper. It would certainly meet the cross-sectional diagram in the manual.
Alternatively, you could put six (or seven or eight as needed) inch segmented bumpers on six sides of the robot, and demonstrate that when drawing a line perpendicular to the bumper back to the robot frame that you have covered more than 2/3 of the perimeter.
In any case, I sincerely hope that you will find a way to make the robot meet the bumper requirements as I'm looking forward to seeing non-traditional drive trains and robot frames developed to meet this year's challenge.
Jason
EDIT: Check out THIS Q&A... you should be okay!
Bumper Qs Woody1458 General Forum 13 29-01-2009 16:41
bumper noodles lopz056 General Forum 3 24-01-2008 21:13
bumper coolguybigt Technical Discussion 4 27-02-2007 16:40
Bumper rules robotraj111 Kit & Additional Hardware 1 19-02-2006 20:36
Bumper or No? WebWader125 Technical Discussion 19 11-01-2006 01:28
