Go to Post Why dress to impress when you can speak to impress? - Joe Matt [more]
Unread 05-02-2008, 18:15
Hazmatt's Avatar
Hazmatt Hazmatt is offline
AKA: Matt
FRC #2645 (PowerSurge)
Hazmatt will become famous soon enoughHazmatt will become famous soon enough
Mounting an arm potentiometer
Hello. I was wondering if anyone could give me any tips, pointers, or general help on mounting a potentiometer to an arm. Any pictures would be cool too! thanks.
Unread 05-02-2008, 19:04
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
Re: Mounting an arm potentiometer
Hazmatt,
How does the arm work? Live or dead axle?
Knowing that we can help you decide the best way to mount it.
Either way, use a flexible coupling like surgical tubing to avoid side loading the potentiometer shaft, which will ruin it real quickly.
Manoel Flores da Cunha
Brazilian Machine
Team # 383
Unread 05-02-2008, 19:10
Michael Corsetto's Avatar
Michael Corsetto Michael Corsetto is online now
Breathe in... Breathe out...
FRC #1678 (Citrus Circuits)
Michael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond repute
A key thing to keep in mind when deciding where to mount a potentiometer is where will the potentiometer get the most resolution. Generally there are two types of potentiometers, 3/4 turn and 10 turn. You'll want to mount the potentiometer where it will take close to full advantage of number of turns, in order to increase the resolution and give your programmers better feedback data. For instance, if you have an arm that goes from pointing directly down to directly up, that is a 180 degree change, and a 3/4 turn pot mounted directly to the arm joint would work. However, if you wanted to have your potentiometer in a slightly less precarious position (ie. not on the top of your robot) you could attach a 10 turn potentiometer to one of the gear/chain reductions (if you have any) that would roughly translate 10 turns of the pot to half a revolution of the arm (a 20:1 ratio), given that the arm is still only traveling from down to up.
As far as actually mounting the pot, be sure not to mount it anywhere where significant side load will be applied, since more than a little side load can break the pot. A safe bet would be to mount the pot directly to the one of the arms drive shaft that is already supported on both sides, via some sort of coupler. We've used pots every year the last 4 years for various things from arms to shooters to crab drives, unfortunately I don't have any close-up pictures on how we mounted them. Hope this helps.
Mike C.
Team 1678: Citrus Circuits - Lead Technical Mentor, Drive Coach **Like Us On Facebook!**
Unread 05-02-2008, 19:18
AdamHeard's Avatar
Lead Mentor
Mike C.
If you buy decent pots, (I'm very partial to the ETI MW22 series. ~$10ish on mouser)you can get 3, 5 and 10 turns.
Also, using surgical tubing as a flexible coupler idea. I first saw 330 do this last year, and have used it in several situations since. Very easy to do, and makes up for poor tolerances. Also, it will slip before breaking the POT if you have it go too far for some reason.
Unread 06-02-2008, 02:44
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
Is there a picture of how surgical tubing and a pot would work ?
History: 624 - Cryptonite --> 118 - Robonauts --> 2158 - AusTIN CANS --> 2587 DiscoBots
Bio: Andrew Lynch "How I Work" ---- LinkedIn , Facebook, Twitter
Unread 06-02-2008, 02:47
Mike Hendricks Mike Hendricks is offline
misses his IFI control system
FRC #0973 (GRR)
Mike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to all
Regarding flexible couplings ..
1388 has used Helicals in the last couple years for adding feedback to our arms. A former 1388 father/mentor is actually one of the engineers at the company.
http://www.heli-cal.com/
You can see it used in this picture on our 2007 bot:
2004-2010: Founding Member, Technical Mentor - Team 1388, Eagle Robotics
2011: ???
Unread 06-02-2008, 05:46
Manoel's Avatar
This is how we did it last year:
Brazilian Machine
Team # 383
Unread 06-02-2008, 10:18
Tapoore's Avatar
Tapoore Tapoore is offline
AKA: Tom Poore
FRC #1519 (Mechanical Mayhem)
Tapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of light
We have used vinyl tubing for mounting pots on several different mechanisms. It works very well, however, sometimes we have had problems with the shafts slipping inside the vinyl tubing. To fix this, we have usually drilled a hole through the shaft and through the tubing and pinned it with a cotter pin (a paper clip works just as well...)
- www.mechanicalmayhem.org -
* 2015 Granite State District Event Champions
* 2013 Einstein Finalists
* 2006, 2010, 2011 Granite State Regional Champions, 2009 Chairman's Award
* 2012, 2013 North Carolina Champions
Unread 06-02-2008, 10:39
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Here is another method.
Unread 06-02-2008, 10:46
Manoel's Avatar
Dead axle, right? I'm looking at our options for this year (too much torque to use a live axle) and yours seems like a good one. Did you have problems side loading the potentiometer? Is the pot shaft pinned against the aluminum channel or is it a simple interference fit or what?
Thanks!
Brazilian Machine
Team # 383
Unread 06-02-2008, 10:50
MrForbes's Avatar
AKA: Jim
The little arm has a clamp screw, and a slot that you can't see that lets it compress and clamp onto the pot shaft. Very little side load, notice the slot where the nylon screw contacts the little arm. Worked fine all season, and we took it off and used it on a different type of prototype robot this year.
Unread 06-02-2008, 11:33
Dan Richardson's Avatar
Dan Richardson Dan Richardson is offline
iR3 Creative
AKA: Dan Richardson
Dan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond repute
This is kind of a different way to do it, Its not suggested but it is a quick and easy and "relatively" reliable way to do a arm pot. I've used this method on encoders and pots on arms and drivetrains, all you need is a little wheel a bit of apoxy to mount the wheel to the shaft of the pot and a rounded area of whatever your measuring.
A problem with this method however is you have to constantly adjust your pot, every match you have to set it to make sure it didn't move and recalibrate.
However if you need a creative solution and can't drill into the end of the shaft or create a special coupler this is a solution we've used in the past and does work, and works well within the 2 minute First matches.
http://picasaweb.google.com/DanRRich...04765271712450
CO-Founder of Robot in 3 Days and the Robot in 3 Day Challenge.
Unread 06-02-2008, 11:58
Alex Cormier's Avatar
Alex Cormier Alex Cormier is offline
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
1126 has used the pneumatic tubing with a little heat to attach it to the pot, haven't had any issues with it.
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
Unread 06-02-2008, 14:30
scottydoh scottydoh is offline
CAD, Mechanical, Alumni, Mentor
AKA: Scott
FRC #0810 (Mechanical Bulls)
scottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to all
Send a message via AIM to scottydoh Send a message via Yahoo to scottydoh
we drive our pot with spur gears, (one on the pot and the other on the drive shaft for the arm), and have had no problems with side loads.
Unread 07-02-2008, 00:33
lynca's Avatar
Andrew Lynch
Thanks for all the helpful pictures !
Human Arm Arm Controller SgtMillhouse648 Control System 5 09-01-2008 00:03
424's 2007 robot arm is very similar to 340's 2004 robot arm. Ross340 Robot Showcase 7 19-11-2007 21:11
Arm mounting on moving tracks? welderman5000 Technical Discussion 4 10-01-2007 00:16
Potentiometer Joshua May Technical Discussion 8 22-05-2004 19:51
Mounting the arm Jesse Technical Discussion 11 10-02-2004 23:20
