Go to Post I think with so many facets of FIRST, success comes from learning the true meaning of teamwork through working towards a common goal. - Kristina [more]
Unread 04-02-2008, 20:35
elvin23's Avatar
elvin23 elvin23 is offline
not cool
FRC #0354 (354)
elvin23 can only hope to improve
Send a message via AIM to elvin23
field
i need to know all measurements not shown in the first 2008 guidelines, tips, & good practices book/manual. can anyone fill me in on this thing?
I never was a cool guy but i would like to be like the guy in the pic he's cool
Unread 04-02-2008, 20:41
Miner Miner is offline
AKA: Jacob Miner
FRC #2077 (Laser Robotics)
Miner is on a distinguished road
Re: field
If you go to the USFIRST website, FRC competition, and documents and updates, there is a whole section of the rule manual that gives all of the dimensions of the field.
Unread 04-02-2008, 20:44
Re: field
Specifically, Section 6 and the links immediately below it.
Unread 04-02-2008, 20:47
elvin23's Avatar
not cool
FRC #0354 (354)
Re: field
but i seen all docs and stuff but couldn't find the measurements for the line marker i seen the measurements and did math but not sure if I'm right
Unread 04-02-2008, 20:55
elvin23's Avatar
not cool
FRC #0354 (354)
Re: field
but i seen all docs and stuff and came up with some bad math
Re: field
Originally Posted by elvin23 View Post
but i seen all docs and stuff but couldnt find the measurements for the line marker i seen the measurements and did math but not sure if im right
The lane divider? That is 6' tall and 27' long, 1 1/2" OD pipe, according to Section 6. The lane divider tape is 2" wide.
Unread 04-02-2008, 21:03
elvin23's Avatar
not cool
FRC #0354 (354)
Re: field
ok im lost cause in 6.2.1 its 27 feet by 54 area but the line marker is in the line divider and the divider is?
Unread 04-02-2008, 21:11
Re: field
54' long, 27' wide. You can fit a 27' long divider plus tape down the middle of the long dimension with room to spare.
To be more clear: the Lane Divider would go at the 13.5' mark that is the center of the 27' field dimension. The center of the lane divider (13.5') would go in the center of the 54' dimension (at 26'). The lane divider is lengthwise with the field.
Unread 05-02-2008, 17:13
elvin23's Avatar
not cool
FRC #0354 (354)
Re: field
so if that is true your turn is? and what happens if its wide? i need measurements for that
Unread 05-02-2008, 17:25
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: field
I'm going to be honest and say I'm not sure what exactly your asking for, but every measurement you could possibly want regarding the field is contained in or can be derived from the documents you were referenced to at first.
The general field layout can be found here:
http://www2.usfirst.org/2008comp/Dra...nd_Marking.pdf
As Eric said the Lane Divider goes in the middle of the long dimension leaving a roughly (very roughly) oval shaped track 13.5' wide all the way around the field.
Unread 05-02-2008, 20:16
elvin23's Avatar
not cool
FRC #0354 (354)
Re: field
you see where it says 2" tape white what are the measurements right there
Unread 05-02-2008, 20:22
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: field
In the 27' direction (width) it is 13' 5.75" as noted in the drawing. in the 54' direction (length) it is approximately the same. If you build the lane divider according to the specs in the other documents and place the center of the lane divider at the center of the lane divider at the center of the long dimension (27' in on the 54' dimension), then the tape runs from the wall of the driver station to the lane divider.
Unread 05-02-2008, 20:29
elvin23's Avatar
not cool
FRC #0354 (354)
Re: field
can you brake it down like a fraction
Unread 05-02-2008, 20:38
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: field
In the 27' it is right in the middle (1/2). In the long direction (54'), it goes
Tape (1/4)
Divider (1/2)
Tape (1/4)
3D Field Cyberguy34000 General Forum 2 05-01-2008 19:59
field JulieB General Forum 1 05-01-2005 17:00
Field ThePaleOne Inventor 4 22-01-2003 18:37
3D Field MattK General Forum 2 17-01-2003 16:43
Field Dimensions archiver 2000 11 23-06-2002 22:27
