Go to Post Adding more weight doesn't make the challenge any easier, it just makes the robots heavier. - Sean Schuff [more]
Unread 05-02-2008, 20:31
holty531 holty531 is offline
FRC #2441
Team Role: Electrical
holty531 is an unknown quantity at this point
<R55> relay 20A
the updated rule 55 says
Rule <R55>
-Each relay module must be protected with one and only one 20A circuit
breaker.
can someone clarify???
the yellow thing in a spike relay module is a fuse, correct?
when used with a compressor, you change the yellow fuse to the 20amp auto reset breaker correct?
so, if there is one 20A circuit breaker in the Spike and there has to be a breaker in the Fuse Panel also right? this equals 2 circuit breakers!
can someone explain how you use only one 20A breaker with the Spike Relay?
thnks.
Relay program? team877 Programming 11 04-02-2008 11:11
Solenoids + 20A breakers. Joel J Electrical 9 23-01-2008 11:22
Relay Commands Matt Krass Programming 6 18-02-2006 23:03
20A breaker sources Rickertsen2 Electrical 2 24-02-2003 21:06
Our 20A and 30A and 40A breakers . . . Frank(Aflak) Technical Discussion 8 01-02-2003 08:36
