Go to Post By the way, a piece of advice to all those who haven't gone to Manchester for Kickoff before: Go. It's something you have to do at least once in your time in FIRST. - Billfred [more]
Unread 05-02-2008, 20:52
Miner Miner is offline
AKA: Jacob Miner
FRC #2077 (Laser Robotics)
Miner is on a distinguished road
Re: Terminal block??????
Just a suggestion, I would use the red wire for positive instead of white. If someone who didnt know much about the board saw that, they may get confused and weird things could begin to happen.
Also where do we connect the power to the terminal block?
You should be able to connect the power on the distribution strip directly to your main breaker panel. I would start with a 20 amp breaker.
Good luck,
Jacob
Do what you like... Like what you do!
Jake, the Life Is Good guy
Terminal Block Big-Bird08 Technical Discussion 2 29-01-2007 19:10
Help needed with finding stud terminal block from KOP amirjpl Electrical 11 25-01-2006 19:32
Power Terminal Block Model Ed Sparks Inventor 1 11-02-2004 06:55
