Go to Post You can never take enough precautions when it comes to safety. Please, be prepared for anything. - Tom Bottiglieri [more]
Unread 05-02-2008, 21:32
IntensifiedAmp's Avatar
IntensifiedAmp IntensifiedAmp is offline
AKA: Muny Tram
FRC #3683 (Team Dave)
IntensifiedAmp has much to be proud ofIntensifiedAmp has much to be proud ofIntensifiedAmp has much to be proud ofIntensifiedAmp has much to be proud ofIntensifiedAmp has much to be proud ofIntensifiedAmp has much to be proud ofIntensifiedAmp has much to be proud ofIntensifiedAmp has much to be proud ofIntensifiedAmp has much to be proud of
Question on Motor Bias
With a finished robot, we're not so finished.
We seem to have a slight problem at extremely low speeds, with our drive train. We're using 4 CIMs, Banebots planetary transmissions, and KOP AndyMark wheels.
At low speeds, when moving the joystick forward, one wheel moves faster than the other. However, when moving the joystick backwards, the other wheels moves faster than the original one.
This implies that at higher speeds, the motors move in sync.
Could this be a possibility of motor bias? Or is it a trimming issue (which by the way, may take forever due to the ultra-sensitive touch) ?
Thanks for the help in advance!
Ah, and yes, our wheels were off the ground at the time.
CIM Motor Bias Direction jonboy Motors 1 28-01-2008 07:58
Charts/Data on FRC Motor and Joystick Bias NeilS Technical Discussion 1 04-01-2007 13:48
Motor Bias gshosford Motors 27 10-02-2006 01:35
Large CIM Motor Bias Ceal Craig Motors 3 09-02-2006 10:20
Accelerometer Bias miketwalker Programming 3 12-02-2005 04:05
