Go to Post Don't be too arrogant as to think that just because you didn't invent it, it is not useful. - ptan [more]
Unread 05-02-2008, 22:28
manderson5192 manderson5192 is offline
AKA: Matt Anderson
FRC #0948 (Newport Robotics Group: NRG (pronounced eNeRGy))
manderson5192 is on a distinguished road
Re: Bizarre Mecanum Programming Bug
We tried using the gyro from the KOP only to encounter frustration in that the gyro would sense angular velocity just fine in one direction while giving random positive and negative numbers in the other direction. I am talking about an output of 15,15,15,15,15 for one direction and 1,-5,16,-15,-4,10 for the other direction. we have decided its simply pointless to mess with the gyro. The arcing I am describing is to the point that the bot strafes in a medium sized circle.
The problem persists in that strafing in one direction (lets say right) makes a diagonal pair of wheels rotate faster than the other pair. Strafing in the other direction yields the same problem but with the other diagonal pair going faster. Does anyone else see this? How do you suggest I proceed?
Mecanum drivetrain programming problems Mr. Freeman Programming 4 21-03-2007 17:11
Bizarre Driving Issue kitscuzz Programming 23 11-02-2007 17:02
mecanum programming mrmummert Programming 27 28-01-2007 13:45
bug? Duke 13370 CD Forum Support 4 30-12-2003 21:44
Bug Matt Leese CD Forum Support 7 14-06-2001 12:18
